Results 1 to 9 of 9
Thread: Sucking jet pump damaged during intake manifold removal
    Nov 2016
    Oklahoma City, OK
    2000 BMW Z3 2.3
    I extracted the intake manifold from my roadster, but not without considerable difficulty. The biggest problem I had was concerning the "sucking jet pump", which supplies vacuum to the brake booster. I didn't see any clear way to detach it, promptly forgot about it, and accidentally broke it when yanking the intake manifold out.
    Here's the two parts: one still attached to the brake booster, and one still attached to the intake manifold:
    It looks like a clean enough break. So my questions now are:
    A) What was the proper method to remove this? Yank it directly from the brake booster? Clip the one-time use clamps, and pull the hose out at the nipple? I haven't seen this covered in the Bentley manual, or any of the intake manifold removal guides I've come across.
    B) Is this something I could just epoxy back together? The two parts still match perfectly. It's a $100 part and I'd like to salvage it if at all possible. But then again, if my fix fails, I would be taking off the intake manifold all over again.
    Here's the RealOEM diagram of the part (#1), 11611439396:
    May 2015
    Maryland
    1998 M Roadster
    From what I see in the pictures, it appears you didn't break the plastic, it just pulled apart. If that is the case, some superglue should bond it back together. To take off the hose, you need to cut off the metal band. I replace the band crimp type clamp with a constant tension (spring) clamp.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    I find that a tiny flat head screw driver can "uncrimp" those. I've even reused a few of those one-time use clamps.
    Nathan in Denver
    Nov 2016
    Oklahoma City, OK
    2000 BMW Z3 2.3
    Thanks for the input. It is indeed separated at the cap. I'm willing now to try to glue or epoxy this back together. I've since found some videos that indicate how it's meant to properly operate, so it should be easy to test to see if it's leaking any pressure.
    I was initially hesitant to try a fix, given the price. The price led me to believe it's an especially sensitive part, but it seems to be pricey simply based upon availability and is actually no more sophisticated than a check valve.
    But why the crimp clamps? Any chance there would be a problem by switching to worm-gear type hose clamps?
    Aug 2015
    Denver, CO
    Quote Originally Posted by Schreier View Post
    No real issue switching. The Oetiker clamps are simply much faster to use during manufacturing. I like the look of them (and the fact that they don't ever loosen), so I do replace factory clamps with like-style. You can buy a box of 50 or 75 in several sizes on Amazon for the price that BMW would charge for 3 or 4 clamps. The crimp tools are kinda fun to use too. I ALWAYS use these on CV boots, or course in much larger diameters.
    https://www.amazon.com/Didamx-7-21mm...r+clamps&psc=1
    https://www.amazon.com/Glarks-120Pcs...oetiker+clamps
    https://www.amazon.com/dp/B01I3H6UIC...547566557&sr=1
    Nathan in Denver
    Jun 2021
    canada
    2000 bmw e39
    would love to know if this repair was done and if it worked? For me I have some slight oozing of bubbles around that joint while doing a recent smoke test. ?
    Apr 2012
    Tucson Arizona
    2001 Z3 3.0 Roadster
    The Oetiker clamp provides constant pressure through heat cycles. Here is a link to where I purchase them.
    https://www.pegasusautoracing.com/pr...p?Product=3295
    Aug 2015
    Denver, CO
    Quote Originally Posted by Pima Roadster View Post
    I use them just about everywhere. They look way better than worm clamps too, IMO of course.
    Nathan in Denver
    Dec 2022
    Sacramento
    Bmw
    Spring clamp vs Oetiker clamps
    Quote Originally Posted by s8ilver View Post
    They do look better but I'm using the spring clamp to tie the hose which is under the sucking jet pump. I have similar situation, and I end up buying the jet pump with the lower house attached to it. I'll use screwdriver to remove the original clamps (Oetiker clamp) and will replace it with spring clamps, especially the ones which doesn't have much room.
  1. Intake manifold remove and reinstall
    By martialartsblac in forum 1991 - 1999 (E36)
    Last Post: 11-15-2006, 11:51 AM
  2. M42 Intake Manifold removal
    By Sarc in forum 1991 - 1999 (E36)
    Last Post: 10-27-2005, 03:34 PM
  3. intake manifold removal, gas lines?
    By anylouder in forum 1991 - 1999 (E36)
    Last Post: 06-06-2005, 08:08 PM
  4. Intake Manifold removal
    By atlantisvip in forum 1991 - 1999 (E36)
    Last Post: 04-30-2004, 09:08 PM
  5. Clutch install easier with Intake Manifold removed?
    By vjlax18 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2004, 03:09 PM
