Results 1 to 14 of 14
Thread: Thinking of buying e38 for daily - what motor?
    Mar 2018
    poland
    e34 m50b20 '95 NV
    Hey there, im switching from e34 to e38 probably, thinking of motor to chose, only city driving, lots of traffic etc, about 50 km daily driving.
    I've been hearing lots of good stuff about 2.8 engine but on the other hand, much ppl saying that they overheat in e38 very often, is that true?
    I dont need an rocket, 6sec to 100 etc, i just want reliable engine that will last for long with good maintenance and quite low (as for e38) maintenance and fuel economy.
    Also, m60b30 seems to be very often skipped with opinions of outdated and expensive V8 that also exists in E32, so guys, what would be the best choice?
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Forgive me if I don’t know what’s available in Poland but in US E38s only come with V8 or V12. Do NOT get V12 unless you have limitless $$ and a spare car for when it’s in the shop. I loved driving my 2000 750iL when it was in good health, but, every 6 weeks or so something would go wrong and I’d be back to the mechanic for serious money.
    If it’s possible to get a 2.8 into an E38, I believe you’d be seriously under powered.
    So, I’d get a V8 but try and make sure it’s had the timing chain/guides done (replaced).
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Mar 2018
    poland
    e34 m50b20 '95 NV
    I got used to underpower (m50b20 with auto trans in e34), but thats not the problem, i cruise mainly or stay in traffic so i wouldnt use more power to be honest.
    I dont even consider anything higher than 3,5L so V12 is a no no
    From what i've seen we've got there:
    m60 with 3.0 or 4.0
    m62 with 3.5 or 4.4
    m52b28/m52TU28
    and couple of m73 which i dont even look at
    Oct 2007
    Bolton, MA
    My current 2001 740iL has the M62. I love it. Has 189k miles, very reliable, does 27mph on highway, 17mph city. Very happy.
    Good luck.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    There's nothing wrong with the M52TUB28, paired with the 3.23:1 differential it takes off pretty sharpish and is surprisingly frugal on a cruise - it just runs out of puff above 90 MPH.
    The M62TUB44 is the 'best' engine for performance, but the complication of Vanos does make it a bit noisy and less reliable.
    I think the best of the bunch is the M62B44 - especially if you replace the 105C thermostat with an 85C stat - they are usually trouble-free and have a lot of grunt....
    My BMW Repair YouTube Channel
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Timm is right, M62TUB44 would be perfect but too many headache with VANOS. It could get costly to replace or rebuild all the VANOS related parts (units, solenoids). You dont have those issues with M62B44.
    Best would be of course a M62TUB44 where PO already did all the VANOS work for you
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    It’s all about money...
    in Europe, with high petrol prices, the 728 would be a great choice. There are plenty on M52 engines and parts and maintenance would be easier and less expensive. Additionally, the M50/52/54 engines are probably the most reliable engines BMW ever made. My M50 in my e34 did not break down until 240,000 miles, until then, it needed very little maintenance. None of the V8s I have are anywhere near that reliable, they all need maintenance.
    If if you have money to burn, go with a V8, but if not, the 728 will be very reliable and much less expensive, just not as powerful.
    Jan 2016
    Poland
    97 e36M50b20nv; 97 740i
    Quote Originally Posted by kouks View Post
    In Europe we run v8 engines on LPG so fuel price is not an issue.
    Feb 2009
    Pikesville, MD
    '01 740i Sport, '13 Volt
    Hmm, I've heard that the V12s are actually more reliable in the later cars, as they don't have the timing chain guide issues, VANOS issues, or valley pan gasket issues. The radiator is the same basic unit and can be brittle and need replacing every 100k miles, but the rest of the car is the same basic car as the V8 and 6 cyl versions. Keep up on the batteries and regular maintenance, and you should be good to go. Both my V8 cars were quite reliable (a '98 and an '01 Sport) and my next E38 will most likely be an '01 750iL Sport.
    May 2013
    Rochester, NY
    2001 740i Sport
    The V12s are more complicated and finicky than the V8s (mostly from the electronics perspective), but have less major mechanical concerns.
    Mar 2018
    poland
    e34 m50b20 '95 NV
    it will run on LPG, obviously fuel ecenomy is one thing, but mechanical reliability is second, i think 2.8 is the way to go, ill probably miss the v8 sound etc but.. maybe someday
    Jan 2016
    Poland
    Quote Originally Posted by shiremux View Post
    V8 is just expensive to maintain as it is more complicated. And for some reason same parts for the 6 cylinder are 4-5 times more expensive on the v8 like the intake boot for example.
    They are both equally reliable when maintained properly. Member here just recently posted 400k miles engine photos which he maintained himself for years. Even timing chain is still original, guides and all...
    Mar 2018
    poland
    e34 m50b20 '95 NV
    what is the lifespan of the timing chain in the m52b28 and the m60 range?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Close enough to forever on both engines....
  1. Thinking about buying an E30 for daily
    By Balthazarr in forum 1983 - 1991 (E30)
    Last Post: 01-18-2005, 08:03 PM
  2. thinking about buying an e38?
    By dqm3 in forum 1995 - 2001 (E38)
    Last Post: 02-11-2003, 09:04 PM
