Results 1 to 12 of 12
Thread: E36 Speedo Recalibration after size change?
    Aug 2018
    SoCal
    2004 BMW E46 325ci
    Hi, I’ve never changed wheels sizes before and cannot seem to find a definitive answer. If I change my current 205/55r16 into 215/35r17 would I need to recalibrate the speedo on my 99 e36 323ic? No stretch btw.
    I’m planning to run the style 5s that came w the e39 528i.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I will move it to the E36 forum
    Oct 2013
    The Netherlands
    2011 E90 325xi
    Your current diameter is 24.9” and your new one will be 22.9”. There will be a big error.
    You should stick with original wheel sizes.
    225/50R16 And 225/45R17 (245 also fine). There’s 0 error between those sizes.
    Jan 2016
    Ca
    2001 525it
    Is it really going to make that big a difference
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    People run the Style 5 regularly. They won’t fit as much rubber as wheels with the proper offset but most people who do this are into looks not performance. Just do the math or use a gear calculator or the gps on a map app like Waze to figure out tgevspeedo difference and remember it so you know your real speed. There is no easy speedo recalibration that I am aware of though some smart person might be able to figure one out.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    It wont be off by much. Think of it this way, the m3 (same car) takes stock like 235/40/17. Your size 215/35/17 is very very little difference, actually smaller than stock m3 tire size.. So.. Your Speedo will have very very little difference. I think with considering the Speedo is already 2mph under any given actual rate, the most your looking at is maybe 3 or 4mph faster at 60mph. I happen to run 245/45/18 on my pandem up front with 265/35/18 on rear and found myself only 4.5mph faster than my Speedo at 60mph compared from radar gun.
    -Oakdizzle
    Oct 2013
    The Netherlands
    2011 E90 325xi
    There will be a different of roughly 10 mph between your current and new size. I didn’t compare it to stock size to see how much it differentiates between those.
    Nov 2013
    Oneida, NY
    At what speed tho? It cant be just 10 mph across the board thats not how ratios work.
    -Oakdizzle
    Oct 2013
    The Netherlands
    2011 E90 325xi
    Quote Originally Posted by spyderg0d View Post
    Yeah true I calculated with 100 mph.
    Nov 2013
    Oneida, NY
    You drive it like you stole it dont you?
    -Oakdizzle
    Jun 2005
    New England
    That’s a good cruising speed.
    Oct 2013
    The Netherlands
    2011 E90 325xi
    Yeah I’m Dutch. It’s part of the culture.
  1. e36 m3 clutch pedal still bent after bushing change
    By moarpower in forum 1991 - 1999 (E36)
    Last Post: 09-05-2015, 08:13 PM
  2. E36 BMW e36 engine head gasket cam change tools
    By Alphanumeric1 in forum Engines, Performance Parts & Software
    Last Post: 08-25-2011, 08:33 PM
  3. Differential change; Speedo recalibration?
    By Rick in Denver in forum 1976 - 1989 (E24)
    Last Post: 05-30-2009, 02:16 AM
  4. E36 tire size change- speedo off by ??
    By st600r in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-17-2006, 10:09 AM
  5. Replies: 4
    Last Post: 09-11-2004, 11:07 PM
