Results 1 to 5 of 5
Thread: 2006 E90 330i Overheating
    Jan 2019
    Renton, WA
    2006 BMW 330i
    I have a 2006 E90 330i were I just replaced the water pump, thermostat and radiator after my daughter ran into a pickup truck. I have bled the system from looking at youtube videos and I'm still worried something is borked. Also, the fan won't start after running 12-15min or with the A/C on full blast. I've checked the top hose gets pretty hot and the lower one between the radiator and thermostat is cold. Any pointers to look for? Can I check a fuse or something? No error codes when I put a scan tool or on the dash panel. I turn the car off after I start seeing some steam coming from the radiator area. Any suggestions will be greatly appreciated. thx
    Jan 2016
    Ca
    2001 525it
    How was the radiator damaged and not the electric fan, just asking. So when you bled it, the heater controls were full warm and when it was bleeding via the electric water pump you should have seen a pretty active little stream of coolant going back into the expansion tank, this is at the top of the tank right below the where the cap screws down.
    Jan 2019
    Renton, WA
    2006 BMW 330i
    My daughter drove the car into the back of a pickup truck. The a/c condenser and radiator took most of the damage except for the fan. When I bled the system I did have the heater controls at full heat and the fan at low, 10sec on the gas pedal and I could hear and see the stream of coolant coming into the tank. Let that run for 12 min or so. Prior to the accident the system was working fine, I replaced those components like the thermostat and water pump since I already had the front end off.
    Jan 2016
    Ca
    2001 525it
    The fan is plugged in all the way? Did a bunch coolant get sprayed around because of the accident? You could check fuses. I know with tools like autologic you can run component test to see if the fan runs at all but a shop would have to do that.
    Jan 2019
    Renton, WA
    2006 BMW 330i
    Yes, If I turn the car on and disconnect the fan and reconnect it runs at high speed until I turn the car off. Let me ask at what operating temp is and what point will the car overheat? I been turning off the car at 88c and maybe not letting it reach its operating temperature. I see very little steam coming out of the left side of radiator and I start to panic.
  1. 2006 E90 330i with RPM 505 Wheels
    By ISHIFT5 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-01-2009, 08:25 AM
  2. 2006 e90 330i for sale 27,000
    By e30s50tony in forum 3 series & Z Series
    Last Post: 04-04-2008, 02:44 PM
  3. Brake problems on 2006 E90 330i
    By sportscoat in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-11-2007, 01:51 AM
  4. FS: 2006 E90 330i
    By AF Romulus in forum BMW Cars For Sale / Wanted
    Last Post: 07-23-2006, 05:16 PM
  5. FS: 2006 E90 330i sport premium 6mt
    By MJSRANGER in forum BMW Cars For Sale / Wanted
    Last Post: 05-23-2006, 12:47 AM
