Never driven on. Ended up going with a completely custom suspension, wheel and tire combo. Pics are shown with springs installed. $75 shipped.
Part #: M2-LSBM-9298
FIT: BMW E36 3 SERIES 92-98 (Sedan/Coupe) MODEL
Note: WILL NOT FIT M3 & Convertible model
M2 Performance Lowering Springs are constructed of SAE 9254 Cold Wounded Steel, one of the strongest materials available. The high tensile strength and phosphate powder coating delivers outstanding spring rates that are extremely durable and resist premature “sagging”.
The result is a spring that specifically offers racecar handling, yet maintains smooth and comfortable ride characteristics. Carefully matched springs rates provide exceptional handling, response, control and balance. These springs offer a generous drop to your car while remaining very “streetable” by having enough clearance to avoid bottoming-out; and the lowered center of gravity improves performance and increases stability, as well as enhancing the appearance of the vehicle.
(Note: Spring rates and drop amount vary by different vehicle application and chassis load.)
- Lower rate (Approx.) : 2" Front/ 1.75-2" Rear
- Spring Rate: 300 F / 250 R
Up
Sent from my SM-G960U using Tapatalk
PM Sent
Sent from my SM-N950U using Tapatalk
Thanks bro...
