RM European Auto Parts
Results 1 to 19 of 19
Thread: Bmw 120i
    Dec 2018
    Galway
    Bmw 120i
    Bmw 120i
    Hi fellas
    I have done a scan on my car and its showing a couple of codes
    1. 2E26 ignition coil cylinder #3
    2. 2A70 valvetronic plausibility, sporadic current fluctuations
    Question : if there are current fluctuations would this cause some sensors to missread and show a fault also
    Car is a 2005 120i 87,000 miles
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Personally, I'd want to read those codes and then follow the test schedule with ISTA, BMW's own diag system. The coil is easy enough: replace it. In fact, I'd recommend replacing all 6 coils, and while you're there, all 6 plugs, with OEM parts.
    It would be good to let ISTA run the test schedule on the valvetronic code....but, well...it's a motor....it's setting amperage codes....and it's not an expensive part.
    https://www.pelicanparts.com/cgi-bin...rTech%23item17
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Chris, he only would need 4 coils as BMW started making the 2.0l a 4-cylinder in those cars.
    After replacing the coil or coils, if you don't want to revisit failing coils, clear the codes and see if the valvetronic comes back.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jun 2002
    E39M5, E500 4WD
    Thanks again, Darin...that's TWO things I learned from you today! This one I can blame on not knowing a Euro market car....should have looked it up and seen it was an N46 before I called for six coils and plugs!
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    That is what we are here for, to learn from each other!
    Yeah the euro market can have some odd balls floating around. Some of those cars would sell quite well in the U.S. IMO but it wouldn't show the Luxury brand that BMWNA chases. My son's 2015 114i is like the base model that you can get from BMW, and it still has the analog HVAC, no I-Drive, cloth seats, but it is a good starter car for a college kid.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2002
    E39M5, E500 4WD
    That sounds like a car I'D like, with none of the crap that causes problems ! Now, if only they'd make it with an S14 !
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    I can say the only real convince is the keyless entry and power windows, and it's a 6-speed. That little motor can be tweaked with a tune to push out 200bhp as it is a 1.6l with a little turbo, but I don't plan on doing that as it already gets something like 40 MPG and can go 140 MPH given enough autobahn. Not real quick off the line, but just as fast as the wagon so it can hold its own.
    That car is pretty cheap and would give KIA a run in small cars, but again BMWNA isn't going to bother as sedans are already going out of the American market.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2018
    Galway
    Bmw 120i
    Thanks guys , going to change the coils and plugs , also have a fault code for auxilliary water pump , does this model have the electric water pump
    dworthy's Avatar
    Nov 2010
    Yes, if you have the auto start/stop it will, even with the analog HVAC. At times you will see codes that were stored a long time ago, that is why we always recommend writing every one of them down, and then rechecking about a week later to see which ones come back.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2018
    Galway
    Bmw 120i
    Thanks dworthy
    This one actually has a mechanical waterpump , but is still showing a fault code for auxiliary water pump? Any just an update on my last post , i changed the 4 coils as the engine was runing a bit lumpy and was getting fault codes for voltage fluctuations for tbe valvetronic , car is now running nice on idle and no voltage fluctuation codes for the valvetronic or the dme .also auto gearbox improved 100%
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to www.realoem.com and enter the last 7 characters of the car’s vehicle identification number (VIN). Hit enter and bookmark the page. Scroll down to engine and check for an auxiliary water pump.
    Dec 2018
    Galway
    Bmw 120i
    Thanks marco
    dworthy's Avatar
    Nov 2010
    James, I am not talking about the motor's waterpump, this one is for the HVAC, the heater. That is why I had asked about the auto start/stop feature, as those cars will have one. Typically they are found on the passenger side frame rail on the right hand drive cars if I remember correctly.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2018
    Galway
    Bmw 120i
    Yes , you are right dworthy it is the hvac pump , i found it and checked it and ots not working , so thank you fpr that , i have sourced a 2nd hand one and am going to replace it .
    Cheers
    J
    dworthy's Avatar
    Nov 2010
    Here to help, and do let us know if the repair does work to close out the thread.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2018
    Galway
    Bmw 120i
    For sure, forum is really helpful
    Dec 2018
    Galway
    Bmw 120i
    Hi Fellas, its me again have been driving my 120i over the last few weeks but am getting very poor fuel economy .
    Any ideas ?
    Cheers
    dworthy's Avatar
    Nov 2010
    Welcome back, maybe....
    By poor, what are the numbers you are getting? What type and conditions are you driving the car in?
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2018
    Galway
    Bmw 120i
    I have not really done any numbers i just know i am putting in a lot of fuel for very little mileage ,
  1. 2006 BMW 120i AT
    By RnL in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 11-01-2011, 01:00 PM
  2. Info BMW 120i
    By luisfilipe in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 01-06-2009, 04:48 PM
  3. Serie 1 BMW 120i (2005 model)
    By ajamiolkowski1 in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 07-17-2008, 01:39 AM
  4. BMW 120i Fuel Consumption - High
    By Smart7 in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 08-07-2006, 08:41 PM
  5. Supercharger kit for bmw 120i ?
    By sparhell in forum Forced Induction
    Last Post: 01-08-2005, 01:49 PM
