Results 1 to 10 of 10
Thread: First BMW...Please HELP!!
    Jan 2019
    Virginia Beach, Va
    2003 BMW 325i
    Hello everyone. I just bought a 03 325i. It had a rough idle and had needed some mechanical work. I fixed all of it so far (bad MAF, vacuum leak, misfire on cylinders 3 and 6) so I test drive it, and when I pull back into my driveway the "BRAKE" light on the dash lights up yellow, and the yellow triangle with the exclamation mark and circle around it lights up as well. I read codes, no codes found. What are these lights? I've looked at brake pads (all are good), rotors (good). Thanks in advance.
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    I’m sure someone with more experience will chime in but the “triple death” set of lights (did you say the ABS was on too?) is pretty common. And usually not a big deal. Not sure why there’s no error code but maybe a speed sensor is bad. Those things are exposed to the elements, get thusly dirty, and can trigger those lights coming on.
    Sometimes, after turning car off and then back on can correct, or disconnecting the battery for a few hours.
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Oct 2007
    Bolton, MA
    If you do disconnect the battery- make sure you know the radio/security code in case you need it when battery reconnects.
    Jan 2019
    Virginia Beach, Va
    2003 BMW 325i
    Appreciate both responses. No ABS light, just those two. I was reading that those lights will limit engine power like a modified limp mode, but i had good throttle response during test drive. The lights are steady too, they never blink or flicker. As soon as I turn the key to start it up they pop up and stay on. Also during the test drive, the speedometer was working fine, but didn't think to test the cruise control. Not sure if that additional info will help anyone
    Jan 2019
    Virginia Beach, Va
    2003 BMW 325i
    Dec 2013
    Chicagoland area
    EXOTICS
    Perform a diagnostic scan with BMW scantool/software,
    that will reveal more than a generic OBD2 scanner.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The audio system in the E46 does not use a code for security. That was the E36.
    Jan 2019
    Virginia Beach, Va
    2003 BMW 325i
    Just wanted to give an update. So I put in a new front left speed sensor, pulled the others and cleaned them. Just went to test drive and before even getting out of my driveway the lights cleared. It's a band aid for now, but no lights mean it passes Virginia Inspection.
    Oct 2007
    Bolton, MA
    Well; that’s ...good. Hope the lights stay off
    Dec 2013
    Chicagoland area
    EXOTICS
    Thanks for the update, you should be fine with that new sensor.
  1. First BMW purchase? HELP please!
    By Chrisj23 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-03-2012, 10:43 AM
  2. Buying First BMW.. Please help
    By pathwal in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-13-2010, 11:06 AM
  3. Buying First BMW.. Please help
    By pathwal in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-13-2010, 05:56 AM
  4. Hate to do this, but selling my first BMW. please Help!!
    By RS4Drew in forum 1988 - 1996 (E34)
    Last Post: 06-27-2008, 08:01 AM
  5. my first bmw please help...
    By SOVAIN in forum 1999 - 2006 (E46)
    Last Post: 09-17-2007, 08:29 AM
