Results 1 to 20 of 20
Thread: Clunk when pressing and releasing brakes
    Jan 2018
    Chicago
    01 540ia
    Question Clunk when pressing and releasing brakes
    Hi guys, for the past couple weeks there's been a clunk/click when I press the brakes or when I let off them
    Videos: https://drive.google.com/open?id=1Nk...15bCicJ0KVt-Sk
    I'm not able to get in my garage right now to get under the car and check for myself. Any ideas? The front pads were replaced fairly recently and still have a lot of pad left. I've noticed it takes longer to brake now and there is sometimes a squealing noise as if my pads were worn. The clunking noise does not happen every time but 90% of the time it does.
    May 2010
    Allentown, PA
    1997 528 Auto 03/'96 M52
    I am by no means an expert and I'm sure others can give better advice, but... it doesn't sound like a "brake pad" issue. It sounds more like a suction-type clunking - it's "softer" than a normal clunk. Again, without being all that knowledgeable here, have someone pump the pedal and see if the sound comes from the master cylinder area under the hood. Are you sure it's coming from outside the car and not from where the brake pedal goes through the firewall?
    What is the brake fluid level? Does the pedal feel any different under foot... softer?
    The squeal may or may not be related. Could be that the calipers were improperly greased.
    Jan 2015
    Shreveport Louisiana
    cant get either vid to play, but it seems like a pad sticking in the caliper getting released when the rotor begins to turn
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Since we are playing "What's this noise.", my guess would be caliper bracket bolts not torqued properly.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    I second. Check the calipers.
    Bad calipers or caliper bolts -not torqued, or most liquely not well greased.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The answer is.....Crickets so far have the floor.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by StephenVA View Post
    Chirp Chirp...Fedisrico where are you?
    So does it make the noise when you are not driving the car and you just step on the brake pedal.
    I listened to your video, seems like the noise is coming from inside the car.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    It’s the nut behind the steering wheel.....
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Time to burn this one... .
    Meanwhile all my stuff is in the garage or under covers due to snow, salt and ice. Mini van time! Oh the life!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Mine does a similar noise, but it kind of cringes or crackles when you press and release. Time to dismount them calipers and check rubber guide bushings and such, and renew the guides/pad ears lube, it seems.
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Frikkin bizarre winter this year.
    We have had, for all practical purposes ZERO snow this year. One or two dustings, but I literally have not picked up the snow shovel once, aside to carry it from the shed to the garage back in December. Meanwhile my sis in Richmond is sending all kinda snowman/sledding pictures and crap.
    #threadjackweathertalk
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2014
    Alexandria, VA
    The news this morning said Los Angeles got some snow.end of the world, as we know it....
    Mar 2010
    Quote Originally Posted by BimmrMeUpSnotty View Post
    "and Snotty feels fine" ?
    2003 M3CicM6 TiAg
    Former:
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    A ha ha....
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    In the wood
    02-530 stick Blown
    Winter brings nothing but bad news so far. Seized caliper and leak radiator. Bimmers are down hard. Driving around now in a POS Chebby.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Hell duct tape will fix those issues....
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Feb 2014
    Alexandria, VA
    If proper maintenance was properly followed, you wouldn’t have had to take three steps down in society like you had to. Enjoy driving those..... ... . things...
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    OOOOOh, a late night slam.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Jan 2018
    Chicago
    01 540ia
    I was able to get my car in the garage, took the wheels off and the sound didn't seem to come from any caliper, bled the brakes and still no change. The sound also isn't coming from the master cylinder. It seems to come from the middle of the engine somewhere below, no idea what it is.
    I'm going to try dennis's suggestion and check where the pedal meets the firewall, the sound doesn't come from either wheel
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    This is a stretch, but did you verify that the springs that are on the back of the inboard pads, that press into the caliper piston, are properly holding the pads in place? This typically manifests as a clunk when going over small bumps/road imperfections when the brakes are not applied. I guess if these were really loose you could get some noise when pressing/releasing the brake pedal.
    Once the inboard pads are inserted into the piston there should be no movement at all.
  1. Front suspension clunk over bumps & releasing brakes
    By jeanhank in forum 1975 - 1983 (E21)
    Last Post: 05-23-2013, 11:59 PM
  2. Front End Clunks and When Applying and Releasing Brakes
    By stupenal in forum 1992 - 1999 M3 (E36)
    Last Post: 06-27-2008, 04:07 PM
  3. How do you release brake pads from caliper?
    By Zeegar in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-27-2003, 04:36 PM
  4. clunking from left front when braking in reverse
    By mmaigret in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-28-2002, 02:27 PM
  5. "Clunk" from swaybars, suspension or brakes? Long...
    By HeyJay in forum 1991 - 1999 (E36)
    Last Post: 01-16-2002, 09:35 AM
