Results 1 to 25 of 43
Thread: 95 525i Blower Motor
    Feb 2017
    Minneapolis, Minnesota
    1995 BMW 525i/5
    It seems my blower motor is going squeaky on me. In an effort to prevent my project going up in flames (literally) I want to get it replaced.
    I want to replace it with an OEM part, but I can't seem to find the Meyle motor anywhere. The BMW branded one is $400, which isn't ideal.
    Did Meyle stop making the motor? Can a different model's blower motor swap in okay?
    Thanks in advance.
    Sent from my Pixel 3 XL using Tapatalk
    '95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
    Sep 2001
    Sharon CT
    I got a blower motor from parts geek, install was pretty simple albeit tedious. It took me about an hour and half start to stop, i took my time. Budget 2 hours if you havent done too many DIY's and are just starting out.
    Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
    88 Alpineweiss / black E30 M3 -Project.
    Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
    98.5 Tiag Silber /black e36 m3 - Modded.
    99.5 Estoril Blau /dove e36 m3 - Modded.
    07 Crimsonrot /black E83 X3 6spd - Stock..
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by Neel View Post
    What brand?
    I've done enough DIYs to end up with a turbo'd M52 running on MS3
    Great White North
    various
    Rockauto has aftermarket ones for @$100 if you want to go cheap. No quality guarantees
    Pelican parts has Behr and BMW for $200-$250 range
    Sep 2001
    Sharon CT
    I went with ACM blower motor
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    autohausaz presently has the ACM on sale for $100.65 https://www.autohausaz.com/catalog/c...limate_control
    ACM Blower Motor P/N: AM-64111468542 ACM, Cross References: 0157.1015A, 01571015A, BMW 530i, 535i, 525i, 540i, 740iL, 740i, M5, 750iL, 735i, 850i & more
    No own experience with ACM
    Dec 2004
    CT, USA
    e28, e34, e39
    Two years ago I bought this one for $53 shipped. It's still working fine.
    https://www.am-autoparts.com/product...-36758116.html
    And it has a 10 year warranty.
    demet
    May 2017
    Australia
    1989 535i
    You can get a Behr for a pretty decent price. It's about $280 AUD delivered which is roughly about $200 USD. Sometimes it's worthwhile to pay that little bit extra, Behr is an OEM parts provider too so the quality is guaranteed. Some of the cheaper aftermarket blower fans can be a bit noisey from what I've read but it all comes down to how much that would bother you.
    Dec 2004
    CT, USA
    e28, e34, e39
    Behr outsources to china too. Put a Behr and a "cheap" aftermarket side by side and I'll bet you wouldn't be able to tell the difference. Does the Behr come with a written 10 year warranty?
    demet
    NW suburban Chicago
    hiss by my window
    If you can manage to remove the blower cages intact the motor(alone)sold(~$100) for MB 190s works with a minor modification.
    http://twrite.org/shogunnew/fixes/climate.html
    Mar 2005
    Long Beach, CA
    93BMW 525i/95 BMW 540i/6
    If you are worried about a warranty, a good option is to buy the part thru FCP Euro - Lifetime Warranty.
    https://www.fcpeuro.com/page/lifetime-guarantee
    USC Ralph - Long Beach, CA USA
    1989 E34 White 525i (M20) 310,000m (Sold)
    1993 E34 Black 525i (M50) 308,955m
    1995 E34 Calypso Red 540i/6 (M60) 201,254m
    1993 E34 Black 525iT (M50) 138,500m
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by uscharalph View Post
    Right, but they only seem to carry the genuine BMW one, not Behr, so it's like $400.
    May 2017
    Australia
    1989 535i
    Quote Originally Posted by demetk View Post
    Damn, I was unaware of that. What about ACM? I'm pretty sure I read that they're German made. I bought a resistor from them awhile ago and it was good quality.
    Calgary
    95 540iT/6, W8 Wagon 6sp
    I installed an aftermarket blower motor a while back and I regret the decision. The aftermarket one has a much louder fan noise than the OEM one does. I compared the two and noticed that the OEM fan cages have rounded ends on the inner edges of the blades while most aftermarket ones have straight, sharp edges. I believe this is why the aftermarket one is louder.
    If noise is a concern for you, perhaps have a close look at the fan cages. If not, just go with a decent-quality aftermarket brand.
    Great White North
    various
    Pelican lists OEM BMW fan at $215. Not sure how they can offer it at half everyone else sells at but that would be my choice here.
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by zubbie View Post
    That's the one I'm thinking of getting. The only drawback is the lack of a lifetime warranty on it like FCP Euro, but it IS twice as expensive from FCP.
    Mar 2017
    STL
    2017 M3 6sp
    So what exactly is failing in blower motor? I start hearing whistle on 2nd fan speed. Is it blower motor?
    I was curious if there is way to rebuild those. We can change brushes, but what is the other stuff needed?
    Great White North
    various
    It's the bearings in the motors that wear out.. bearings start to drag, requiring more torque and thus more current to run. The wiring is fused wrong so current melts wires, fires start......
    May 2017
    Australia
    1989 535i
    Quote Originally Posted by katit2 View Post
    A squeaking/whistling noise is usually the bearings going bad, for safety you should switch the blower fan fuse down to a 15A or 20A fuse. E34 blower fan fires are very real and I've seen more than a few go up because of it.
    They're not really fixable. I learned that the hard way by having it removed and fixed, but it just failed again 6 months later. Another OEM fan will last the lifetime of the car, being that the original OEM fans have a pretty good run of over 25 years and a new one should last roughly the same.
    Mar 2017
    STL
    2017 M3 6sp
    Quote Originally Posted by CarterH View Post
    I was replacing bushings to fix wipers/hood issue and motor was out. I did lube bushings on motor which obviously didn't do anything. And yes, 20A fuse there already.
    It just slightly chirping and not always, I will keep it for now, just learning.
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    Yikes. Mine chirps on speed 4. I don’t want a fire.
    May 2017
    Australia
    1989 535i
    Don't leave it too long. The lubing will help it for now but it will go bad again in a few months.
    Quote Originally Posted by jmile46 View Post
    It's best not to put it on 4 in that case and you should definitely change the fuse. Putting it on speed 4 actually bypasses the fuse too so it essentially removes the safety of stopping it if the draw is too high and causes it to overheat.
    moroza's Avatar
    BFE
    E34T
    IIRC my Behr was German-made.
    The motors wear out, but also the fan "hamster wheels" can fall apart with age and debris.
    False, at least for US models. See page 6450.5-02 of the factory wiring diagrams. Speed 4 bypasses the resistor, not the fuse.
    May 2017
    Australia
    1989 535i
    Quote Originally Posted by moroza View Post
    Ah, my bad. I remembered it bypassed something but got it mixed up. But if he did have the standard 30A fuse in there instead of a 15 or 20, that combined with the bearings going bad may still lead to some serious heat.
  1. 95 525i wiper motor seized....
    By bimmer94525i in forum 1996 - 2003 (E39)
    Last Post: 08-21-2008, 01:45 PM
  2. 95 m3 blower motor resistor
    By gdrum in forum 1992 - 1999 M3 (E36)
    Last Post: 08-07-2008, 06:29 PM
  3. 525i Blower Motor and Brake light question
    By da9tegra1 in forum 1988 - 1996 (E34)
    Last Post: 10-15-2007, 08:05 PM
  4. 525i e34 blower motor problems
    By soundguy in forum 1988 - 1996 (E34)
    Last Post: 12-04-2006, 10:24 AM
  5. 525I blower motor resistor
    By diesel in forum 1988 - 1996 (E34)
    Last Post: 08-27-2002, 05:24 PM
