Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Air filter fit side
  1. #26
    May 2013
    Canada
    1990/02 BMW 735iA M30B35
    If I turn ignition on than 12V goes to windshield bottom grill without turn front defrost button ?
  2. #27
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You have to try it and test. I assume the windshield grill element will only start after the engine has been started, so that there is full power to the motor starter first. And only when the outside temperature is below 5 degree Celsius the windshield heater will work. And as that is controlled by the IHKA control module via the relay, the IHKA must be switched on probably.
    Try to study the wiring diagrams more in detail.
  1. aFe air filters will not fit.
    By jvsantosmd in forum 2006 - 2010 M5 & M6 (E60, E61, E63, E64)
    Last Post: 05-20-2018, 08:58 PM
  2. Mann-Filter C 25 114/1 Air Filter fit for 2003 BMW z4 3.0i?
    By jlindsey86 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 04-23-2012, 10:20 PM
  3. Coolant leak on passenger side near air filter
    By gyeah99 in forum 1988 - 1996 (E34)
    Last Post: 03-06-2006, 06:44 PM
  4. Choosing Proper Fit for ITG Air Filter....Need Some Advice
    By jmciver in forum 1992 - 1999 M3 (E36)
    Last Post: 06-10-2002, 12:25 PM
  5. Panel Air filter
    By Cock318 in forum 1991 - 1999 (E36)
    Last Post: 03-02-2001, 08:49 AM
