Results 1 to 7 of 7
Thread: 97 m3 rear suspension overhaul questions
    Jan 2019
    houston
    2017 F150, 97 M3
    I have just purchased a 97 M nearing 200k. I want to do a complete overhaul and start with the rear. My question is regarding the rear subframe. If I am replacing all the bushings throughout rear suspension, would it make more sense to take it apart piece by piece on the car rather than dropping the rear suspension all in one shot by removing the subframe with everything still attached to it? All the DIYs I see are people dropping everything at once but I worry about balancing all that on my jack. This will be done in a garage on stands. I am still also looking for a solid DIY for the rear subframe bushing replacement.
    Jun 2010
    NY
    1997 328i
    There's no need to drop it all at once, work at you own pace. Watch some youtube videos.
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Definately easier with the subframe dropped. I did mine on jackstands as well. No way to change subframe bushings without dropping it. Everything else can be done while its attached but it is not very spacious. Dropping the subframe might take you an hour (lift car, undo e brake cable at handle, remove cat back section of exhaust disconnect drive shaft from diff, then undo the 4 subframe bolts.) Maybe 2 hours to replace all the bushings if you have the right tool, then take a break and mount it all back up the next day.
    Jan 2019
    houston
    2017 F150, 97 M3
    I wasn't saying I was trying to avoid dropping the sub frame. I was saying I'd prefer to take the differential out of the sub frame, then take off some other parts from the subframe to reduce the weight and size of everything resting on a jack. I was a little uneasy about lowering that whole structure on a jack. In the end I think the total time may be similar since you have to take all the parts off to change the bushings anyway. Is there any places that rent the special bushing tools?
    Jun 2010
    NY
    1997 328i
    Advance auto parts has loaner tools, not sure if they have one that will fit.
    https://www.youtube.com/watch?v=aoWcjEKbYck
    Aug 2014
    Redwood Shores, CA
    1999 BMW M3 Coupe
    Take the differential out and you can drop everything else out in one go. I didn’t have much trouble balancing it on my floor jack
    Apr 2015
    Tennessee
    1998 BMW 328i
    It helps to have another set of hands for this job. It is pretty easy to drop it all as one unit, but then disassembling it off the car is harder then doing it while its on the car. Personally id take my time and pull each piece one at a time. It will all need to be apart anyway to change everything.
  1. rear suspension overhaul torque question
    By stealth540i in forum 1996 - 2003 (E39)
    Last Post: 05-30-2011, 10:48 AM
  2. 97 M3 rear shocks and RSM question
    By E30wheelman in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2009, 07:32 AM
  3. FS:97 M3 rear subframe/suspension/brakes
    By .Tom. in forum BMW Parts For Sale
    Last Post: 10-02-2006, 12:57 PM
  4. M3 Rear Suspension Questions...
    By Graffix000 in forum 1991 - 1999 (E36)
    Last Post: 11-01-2004, 12:53 PM
  5. E46 M3 rear suspension question?
    By Enigma in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-30-2002, 11:18 PM
