Results 1 to 4 of 4
Thread: HELP!! BMW e32 750il Diagnostics (tiny ADS)
    Jan 2019
    Adelaide, South Australia
    1991 e32 750il
    Hi everyone first time poster long time reader
    Can anyone help me with inpa/Edibas............... i have a old Dell D630 laptop running windows 7 with a true serial port, a 20pin connector with a tiny ads interface with a serial port plug, also running VMware virtual machine.
    I have purchased a program from DJWW auto diagnostics but no luck with the program i am having issues with corrupt files i believe whilst unpacking so i believe i am missing some important files
    I have read many posts on this and i am now very confused with all the different versions of INPA Ediabas and other programs that i might require like DIS, BMW SSS v32
    Can anyone please supply me a link to a working version for my 1991 e32 750il
    Oldham UK
    '00 330i Sprt '92 525i
    You may be better doing a search in the Diagnostic Software forum. Not sure if he is still active but I would look out for posts by David Mc who is in Queensland.
    Don't think you need VMWare for INPA. You will if you run DIS as that runs on UNIX in a virtual drive. IIRC, v44 was the last version to contain programming. HTH
    Jan 2019
    1991 e32 750il
    I have done some more research on here..... I am going to re install the program that i bought from DJWW I think the problem might be that the tiny ads serial port cable might need a special driver as im running this program a dell 630 laptop, the posts i have read i think this might be the problem. I have a usb K-DCAN cable i purchased off ebay (not compatible with my car e32) when i have this plugged in and open INPA/EDIABAS this cable is detected.
    thanks for the reply Whiskychaser
    Oldham UK
    I have been using a Dell 810 for many years without problems. You might check with your supplier if the software will run on Windows 7 as I use XP. Not sure you need to do this with INPA but I have to run ifhsvr32.exe before starting DIS. And IIRC, the first time you use the software you need to run adssetup.exe from the C prompt. It is in the ediabas/hardware/ads/ads32 folder and installs the driver for Windows NT 4.0. Not sure what cables you are using but in my experience, the carsoft ones don't have enough wires connected. As a result, the car is not identified automatically. You may know all this already but in my experience, stumbling around in the dark isn't much fun.
  1. BMW E32 750il Dinan Twin Turbo value?
    By dragon850 in forum 8 Series (E31)
    Last Post: 10-26-2014, 08:26 AM
  2. BMW E32 750IL "Nurburgring" Big Brake Kit - No Longer Available
    By czapa11 in forum Brake Kits, Rotors & Pads
    Last Post: 09-24-2014, 12:23 AM
  3. Replies: 15
    Last Post: 01-25-2014, 09:52 AM
  4. SALE Parts from a BMW E32 750iL
    By b1gturbo in forum 1988 - 1994 (E32)
    Last Post: 08-28-2012, 10:20 PM
  5. WTS bmw e32 750il black on tan
    By sausrigging in forum BMW Cars For Sale / Wanted
    Last Post: 03-28-2007, 09:12 PM
