Results 1 to 11 of 11
Thread: Blower switch in dash or blower resistor?
    May 2016
    melbourne ,australia
    2000 Z3 2.0 manual
    Hi all,
    I've had issues with the operation of the blower resistor before (always running at full speed) and have been able to clean it up to get it working correctly. The current issue is a little different though. All speeds work fine (1,2,3,4). It is just that 0 runs like 1. (the fan won't shut off, unless the key is turned to off in the ignition)
    Is this something that the blower resistor could cause? I'm thinking it might be the switch in the dash itself (which seems clicks into place nicely as it should and always has) that would cause the problem this time. I'm not sure of the wiring to the resistor, but was thinking that it shouldn't get power at all on 0.
    Wondering if anyone can share their experiences if they've had the same problem.
    Edit - just checking the wiring diagram (posted), It does seem like it is the switch if I'm reading it right. 0 shouldn't connect at all. Do any electrical engineers disagree?Screen Shot 2019-01-12 at 12.08.29 pm.png
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Yes, I disagree. So does the diagram you posted. Look at the two feeds labeled A and B, all connected to the low speed circuit.
    /.randy
    May 2016
    2000 Z3 2.0 manual
    Thanks Randy.
    You are correct. They I think come from the AC and Recirculation circuits? It turns out I had recirc on, which is why the 1 speed was blowing even with the fan dial set to 0.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    The blower runs at the lowest (or higher when selected) speed ANY time the a/c circuit is energized. Otherwise, the evaporator coil would be contained in a block of ice, inhibiting airflow.
    May 2016
    2000 Z3 2.0 manual
    That makes sense. Seems that just the recirc even with ac off triggers the fan to run for me. Not sure if that is normal or necessary but it’s simple enough to turn it off. I guess it is designed to keep the recirculated air recirculating.
    Dec 2007
    Great Dismal Swamp
    Exactly. Low speed enabled any time the switch is set to 1, the A/C is on, or the outside air door is closed. They want to keep a bit of air moving through the heater box. My guess is they are trying to avoid that old Ford musty smell.
    /.randy
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by mobilenet View Post
    ... It turns out I had recirc on, which is why the 1 speed was blowing even with the fan dial set to 0.
    This function is mentioned in the Owners Manual without explanation of what causes the recirculation after outside air is blocked.
    Recirculated air mode
    If there are unpleasant odors in
    the outside air, you can temporarily
    block the flow of air. The
    system then recirculates the air currently
    within the vehicle.
    BMW MOA 696, BMW CCA 1405
    May 2016
    2000 Z3 2.0 manual
    Thanks to both of you for the help. :-)
    Jul 2019
    SoCal
    1997 BMW Z3 1.9
    Have the same issue but slightly different. I just changed the blower resistor. Prior to it not working, my fan speed at 0 and 1 are also the same.
    After an hour drive, it noticed some whining then when I changed the blower speed to 3, that's when it stopped working (Except for #4 blower)
    With the new resistor installed, things seem back to normal but it's still blowing at 0 and 1 and I can still hear the whine.
    Does this mean my blower motor is about to be done?
    Why is the blower fan still running at 0? So is the blower fan always running normal? Yes I have the circulation on to prevent outside air because these z3's don't have no cabin filter. (just got the car 3 months ago) Thanks
    SW Florida
    0 & 1 are the same when the a/c is switched on, or the evaporator coil would freeze over.
    Jul 2019
    SoCal
    1997 BMW Z3 1.9
    I see. Same thing with recirculation on to prevent outside air as Vintage stated? Double checking.
    The issue now I have is the whining. I'm not sure if it's been there before. Maybe it's just me.
  1. Heater Blower Switch
    By Rich1983 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-25-2010, 12:20 PM
  2. blower switch only works on high ?
    By gletom in forum 1983 - 1991 (E30)
    Last Post: 10-26-2007, 06:20 PM
  3. 92 325i blower switch
    By josev in forum 1991 - 1999 (E36)
    Last Post: 03-05-2006, 12:08 PM
  4. A/C / Heater Blower Switch
    By pdw1970 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-24-2006, 03:23 PM
  5. blower switch issue
    By zebra in forum 1991 - 1999 (E36)
    Last Post: 02-10-2006, 09:43 AM
