Results 1 to 4 of 4
Thread: E31 Help Needed - White smoke, seat removal
    Jan 2019
    Leicester, Uniter Kingdon
    1995 840ci
    Hi All,
    I've recently had a 1995 840ci delivered to me. An absolute dream car for me.
    Unfortunately, it looks like I might have bought a bit of a pear. There are a few issues (some of which I was aware of) which need addressing. Thankfully, there's a lot of information out there which is really helpful. However, there's a couple of things which I'm struggling with...
    The first issue is white smoke on acceleration. I know that this is regularly attributed to head gasket failure, but neither oil/coolant are low and there's no 'mayonnaise' under the oil filler cap. Also, from what I've found on the M60B40 engine, it would be uncommon for the HG to fail. Is there anything else which commonly causes this with this engine?
    I need to remove both front seats - the drivers seat forward/backward motor isn't engaging and the passenger seat tilt lever is broken. The problem which I'm having is that the drivers seat won't move forwards or backwards to access the bolts. Is there another approach?
    The final issue which I've got is a vibration/judder from the rear. Anything to look at initially here?
    Thanks in advance,
    Ryan
    Feb 2008
    Dayton, Ohio
    93 850ci 6 Spd/2021 530e
    The white smoke could be valve stem seals.
    The following link will show you how to access the bolts to remove your seats. Just go to the table of contents to find the instructions for the seats.
    https://www.bmwtechinfo.com/repair/main/721en/index.htm
    There are threads on this site which show how to fix the seats if the problem is the seat cable. Just do a search for these. Also, be aware the seat is very heavy so you may need someone to help you lift it out of the car.
    Congratulations on the purchase of your car. Hopefully, the smoke is from something other than the head gasket.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It's pretty cold in the UK at the moment - and the big BMW's do bung out a LOT of steam until full exhaust temperature is reached - here's what mine looks like on a cold morning:
    If the smoke is blueish then it is probably burning oil - and the most likely cause on the 840ci is the PCV - quite an easy job on the E31 and described here:
    https://www.meeknet.co.uk/E32/PCV/Index.htm
    It is worth checking the loom under the seat - mine was disconnected when I bought my last E31 - probably caused by something sliding around on the floor:
    https://www.meeknet.co.uk/e31/Front_Seat_Repair.htm
    Vibration at the rear under acceleration is quite likely to be the rear CV joint - a common problem (had it on both E31's and an E38) - the grease hardens and the propshaft fails to centralise - fortunately the CV joint is replaceable as a separate part and reasonably cheap = more on the propshaft here:
    http://www.meeknet.co.uk/e38/e38_remove_propshaft.pdf
    These are all standard problems with the E31, pretty esy to fix, if this is all that is wrong you have a winner!
    My BMW Repair YouTube Channel
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Welcome aboard! I don't know about white smoke only under acceleration. Most likely condensation. When you blow a head gasket, it smokes white all the time--to the point where it isn't hard to diagnose. What happens if you accelerate then lift off abruptly? If your coolant and oil look normal, it might be something to monitor.
    As for seats, the lever that tilts the seat for rear seat access always breaks. The replacement part has been redesigned. It is an easy fix without removing the seat. There is also a lot written if you look up seat twist. The seat won't go forward or backward if it is twisted. Again, a simple fix without removing the seat.
    Brett
  1. Help needed! 750 rear seat back removal
    By wastedincome in forum 1995 - 2001 (E38)
    Last Post: 01-28-2016, 07:48 AM
  2. Need some help with white smoke/steam
    By deadedwalking in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2014, 11:54 AM
  3. Need Help Have White Smoke Coming out of Tail pipe
    By corriebt in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-14-2009, 11:51 PM
  4. Help Needed, Heater blower resister removal
    By matts1 in forum 1999 - 2006 (E46)
    Last Post: 08-01-2006, 06:29 PM
  5. Urgent Help Needed With Spark Plug Removal
    By kpytoi9 in forum 1991 - 1999 (E36)
    Last Post: 07-26-2004, 12:41 PM
