Results 1 to 10 of 10
Thread: Oil Leak when shutting off car...
    Feb 2018
    Camano Island, WA
    2000 528i
    I tried searching but don't see anything more than the common sources of oil leaks...
    My 2000 528i E39 leaks oil off of the last/lower oil pan bolt only when I shut it down. AND it only seems to leak after DRIVING the car, not just idling and shutting down. Weird, right?
    So I've replaced the valve cover gasket, the oil filter housing gasket and the oil pan gasket. With the pan off, it appears that the area around the RMS is dry, so I don't think it's from there.
    It almost seems like it pukes up/burps some oil? I'm wondering if something internally is relieving itself when it shuts down, as I have good vacuum when it's running.
    Thoughts?
    Thanks!
    Mike
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Have you cleaned all the oil off the engine so you can see where it's coming from?
    Are you sure it's oil and not PS fluid?
    Maybe the upper oil pan gasket is leaking?
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Also, may want to check the CVV system. If it's creating positive pressure in the crankcase, it will force oil out thru the weakest points. Try a piece of 8.5x11 paper over the oil filler hole while at idle. The paper should be sucked down onto the valve cover over the filler hole.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Feb 2018
    Camano Island, WA
    2000 528i
    JimLev, didn't know that I had the engine (M52) with upper/lower pan?
    Ed CT, I have good CCV when running, looked into that already. Thought maybe something is releasing though, once the engine is shut off.
    Mike
    Jan 2015
    Shreveport Louisiana
    sure its not just oil pooling somewhere on the engine and later dripping off? as stated before, id clean all the oil off of it, then you can see where the source is.
    Sep 2014
    KS
    e24e30e36e39e90
    Crankshaft seal is another possible culprit. Just had to change mine out (v8)
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by mattmar1 View Post
    Agreed ^^^ After-Driving might mean something that would otherwise drip from the front gets blown-back to rear and when you stop there's still some residual.
    Quote Originally Posted by sienayr View Post
    Except he says:
    Quote Originally Posted by mdearman View Post
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    How much oil are we talking about? Puddles on the ground? If not, just leave it alone.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    My guess: a cracked valve cover
    Apr 2008
    Australia
    E39 99 528iT
    I had a similar oil leak which only occurred after the engine was shut down.
    When the engine is running the crankcase vacuum is sufficient to keep oil inside the engine. When you shut down the engine there is no longer any vacuum in the crankcase. Oil draining back from the upper reaches of the engine can leak out. In my case it was the oil pan gasket that had a slight leak. It had become hard and brittle and had some cracks in the rubber part of the gasket - it is a thin steel strip with a rubber coating on each side.
    When you replaced the oil pan gasket did you put RTV sealant as required in the 4 locations around the bottom of the crankcase where the timing chain case and the rear main seal bolt to the crankcase?
    These joints have a tiny chamfer on the edge and if they are not sealed with DreiBond 1209 (3 Bond 1209) or equivalent you will get oil leaks from these joints.
    You can also get oil leaks from the valve cover gasket if you don't put RTV sealant on the 8 sharp corners where the half moon parts of the gasket fit into the head.
    Since the engine is tilted to the back and to the right any oil leaks from the VCG will end up in the lower RH front or rear corners of the block.
    I hope this helps.
    RonR
    99 528iT M52TU 5HP19
    RHD Euro Spec
  1. 2008 335i Oil Leak - repair or sell car?
    By gurdeep in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-01-2016, 09:28 AM
  2. All of a sudden my car has an oil leak....
    By GardenBeast in forum 1991 - 1999 (E36)
    Last Post: 06-29-2007, 12:10 AM
  3. Please Help...Oil Leak...I hate my car!
    By stimpe36 in forum 1991 - 1999 (E36)
    Last Post: 06-09-2007, 07:30 PM
  4. Started the car and had oil leak
    By MikeHsu in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-02-2006, 05:05 PM
  5. car trouble \ oil leak, could this be due to rod bearings?
    By 02m3con in forum 2001 - 2006 M3 (E46)
    Last Post: 10-25-2004, 09:33 AM
