Results 1 to 7 of 7
Thread: S257SX-E .82/83: Am i making a mistake?
    Florida
    '87 325is 24v turbo buil
    S257SX-E .82 a/r: Am i making a mistake?
    Hey everyone, i am nearly finished with my turbo m52b28 e30 build, and at the last minute i realized my hy35 just isn't going to work due to compressor housing not meeting up properly with the manifold, etc. (I hadn't tried actually bolting it on, just sat it on for mock up purposes, don't flame me)
    I am building a weekend track/street car looking for 350-450whp. I am looking for a fairly quick spool and the most power under the curve possible. I was recommended the Borg Warner s257sxe, but wasn't recommended a turbine housing size. I am thinking an .82 a/r as i have a rapid spool/good and tight manifold and this looks to be the right size. I am trying to make a quick decision as i was looking to start the car this weekend, though that clearly isn't happening...
    Am i making a mistake here? Are my IAT's going to be too high on the track? Am i picking the right turbine size?
    Thanks in advance.
    also, the title was supposed to say .82 a/r, but i can't edit it apparently...
    Nov 2013
    Gerrrmany
    E34 Turbo
    FL
    are slow.
    Should be fine with a .82 A/R. With a S257sxe expect full boost really quick though, and in an e30 that much torque so early on is going to be a handful in the lower gears lol.
    -Dr. Seuss
    Florida
    I hope so! I am running 245's with sticky rubber. I plan on doing full aero for track use and everything else i can do to add grip (mechanical and aero)
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Will be great. I had a s256sx on an s52 that tapped out at 465. A 257sxe will do north of 500. Will be a great turbo for your intended use.
    Florida
    Thanks everyone for the feedback. Turns out one of the places I was considering ordering from is local, so hopefully I can pick up this turbo today.
    Apr 2006
    Minnesota eh?
    86 325es
    Sounds like a good match for the goals to me.
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  1. New Dinan Free Flow Exhaust F80/82/83 M3 M4 D660-0050
    By BMWWYO in forum Engines, Performance Parts & Software
    Last Post: 08-09-2018, 10:51 AM
  2. Replies: 0
    Last Post: 05-30-2014, 04:41 PM
  3. Save me from making a mistake...
    By Justin(OKC) in forum 1992 - 1999 M3 (E36)
    Last Post: 12-27-2005, 11:46 AM
  4. Did i just make a mistake???
    By rorrick in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2003, 01:48 AM
