Results 1 to 3 of 3
Thread: NCS Expert coding inquiry for TPMS retrofit
    Nov 2009
    USA
    2000 328Ci AW
    Greetings to all
    Is is possible to add a new function line to a module file and have it work properly with NCS Expert? The coding instructions include 2 specific lines that need to be set to “aktiv” but my DSC and KMB module files do not have these functions.
    Will adding the lines manually function? Are there lines specific to the file version that do the same as the two lines my modules do not have which will enable the retrofit to work?
    line: CAN_RDC aktiv (found in KMB_E46.C08 to my car’s KMB_E46.C03.
    line: REIFENDRUCKWARNSYSTEM aktiv (found in MK60) to my cars MK20E_I.C03 file.
    This is in attempt to get the TPMS retrofit (http://www.zhpmafia.com/forums/showt...e-doityourself) fully functional as i have coded the other three lines needed by the KMB (as per the zhpmafia instructions) and now need the two lines listed above to see if this works.
    Upon initial ignition start up the TPMS icon turns red and then back to yellow as it should but stays on all the time.
    Here are the coding instructions Loading...
    Regards, Mark
    Jul 2004
    Houston, TX
    36 Cylinders
    That is near impossible, as those bits and bytes we change in coding are referenced in the programming/logic area of the module.
    If the older module version doesn't have that logic, then adding those coding parameters wouldn't do anything.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2009
    USA
    2000 328Ci AW
    Yes i came to that conclusion.
    Thanks Abel.
  1. CIC retrofit NCS Expert coding issue
    By Markk in forum Diagnostic Software
    Last Post: 05-15-2023, 10:26 AM
  2. NCS Expert coding for remote Window up/down - E46 M3 Coupe
    By calrick02 in forum Diagnostic Software
    Last Post: 03-12-2014, 04:09 PM
  3. NCS Expert Coding Driver/Passenger Windows Up/Down
    By cnsxskillz in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-06-2012, 02:27 PM
  4. NCS Expert coding E87 retrofit LED tail lights?
    By ogee in forum Diagnostic Software
    Last Post: 10-22-2011, 12:34 PM
  5. NCS Expert coding faulty
    By 99frc in forum Diagnostic Software
    Last Post: 07-28-2010, 03:20 PM
