Results 1 to 21 of 21
Thread: Rear Tranny seal on 98 M' Roadster
    Oct 2018
    Surfside, Fl
    1998 BMW Z3M Raodster
    Hello,
    Looks like I have a slow leak from the rear transmission seal. Does anyone have an idea how many hours it would take a shop to replace the seal? Looks like the exhaust needs to be removed to perform this job. Just trying to get an idea of how much to expect to pay without the shop trying to gouge me.
    Thanks for your input!
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - take a look at the link below to our site's DIY tech articles on the transmission. It'll give you a good idea of the time-frame and cost for certain procedures. Hope this helps you out a bit.
    https://www.pelicanparts.com/BMW/tec...m#transmission
    888.280.7799 | 6am - 5pm PST
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Are you sure that its the rear transmission seal that is leaking? The gear shifter seal above it is the usual culprit.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Oct 2018
    Surfside, Fl
    No, I'm not sure. That's good advice, i'll need to verify. Thanks
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    You have a ZF transmission. It is not the same as the Getrag Pelican pointed you to.
    The bad news. If it is the rear seal, it can not be changed without special tools. The flange is a serious interference fit, requiring a hefty puller to remove and a special tool to press it back on. If you try and drive it on with a hammer as suggested in the DIY, you will destroy the 5th gear synchronizer assembly.
    The good news. On the ZF it's always the shifter shaft seal.
    /.randy
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Shift-shaft seal; I've replaced dozens upon dozens of them.
    Oct 2018
    Surfside, Fl
    Quote Originally Posted by Randy Forbes View Post
    Is the Shift Shaft seal the same as the Selector shaft seal? If thats the case then I already replaced it a few months ago and perhaps its leaking again.
    Feb 2004
    VA
    I need to do this one now on the coupe. I noticed it on the roadster I sold but the coupe is definitely leaking. Easier to spot in roadsters because they don't have that plastic floor that retains much of the drip.
    Anyway, is the concencus to still tap another one in vs trying to remove?
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Quote Originally Posted by workhurts View Post
    Or a good tip on how to get the old one out. In for answers.
    Oct 2018
    Surfside, Fl
    How many hours would it take a competent mechanic to replace the shift shaft seal on an M roadster assuming exhaust needs to be removed. Thanks
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    3 hours, per Pelican.
    SW Florida
    Quote Originally Posted by OCRentAPopo View Post
    I have long been an advocate of pushing the existing seal inward (1/4-5/16"?) and putting the new seal in over the top of it.
    The primary reason is to eliminate any potential damage to the surface of the shaft (shift or selector, same thing here) as once it's scored, you're screwed as far as sealing goes. A secondary benefit is that the old seal will now be working on a new section of the shaft and the new one only has to deal with the slight dribble that gets past it.
    ALWAYS (ALWAYS, ALWAYS!) lubricate the seal before installation. ALWAYS!
    Our (other) esteemed Randy on here warns that if the seal is driven in too far, that it will foul the range of motion, so only go in as far as necessary to seat the second seal (I've probably done this seal replacement 40-50 times, and never experienced too far__and that was before the warning).
    There are however, a couple of tools that I only recently discovered__thanks to someone on here posting about them__and one removes the existing seal and the other is to drive a new one in. I'm undecided if I'll continue doubling up the seals, although I do get a kick out of working with new single-purpose tools...
    Extractor:
    Installer:
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Awesome write-up as always, Randy. Truly appreciated.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    No one does tool porn like Randy
    Feb 2004
    VA
    Quote Originally Posted by z3forlife View Post
    I must insist on the removal of gloves for future pics plus more oil. Thanks.
    Were the tools expensive or difficult to order?
    Dec 2004
    Parma Heights
    '00 Z3M, '06 Z4M
    Sorry to bring this back, but has anyone done this without removing the exhaust and the driveshaft?
    Check out my M Roadster projects and DIYs:
    Cooling system part 1: https://youtu.be/ERqztIL1DPw
    Cooling system part 2: https://youtu.be/-DnclDkn2hI
    Power convertible top: https://youtu.be/KLYNqkCBh_M
    Head unit removal: https://youtu.be/LKe9fPKrAqE
    Dec 2018
    Indiana
    00 M Roady '22 Lexus RC
    Quote Originally Posted by Andryuha View Post
    I just did this a week or so ago. I don't think it's possible, here's some pics and you can see the transmission tunnel all around the top and sides. Then look at where the Giubo attaches, if it wasn't off, you wouldn't be able to see it. Plus you have to disassemble part of the shifter linkage to be able to slide the new seal over the shaft.
    Apr 2020
    Ontario, Canada
    1999 Z3
    Quote Originally Posted by IndianaRoadster View Post
    So I guess the bronze looking end of the seal goes to the outside. I haven't done the job yet but I was wondering.
    Did you double up the seals? If not, how did you remove the existing one?
    Dec 2004
    Parma Heights
    '00 Z3M, '06 Z4M
    Argh, I just replaced my guibo and CSB, but I needed to have the car back together. I guess I'm going to have to disassemble it all again. FML.
    Dec 2018
    Indiana
    When you go back in, that would be a good time to replace the shifter linkage bushings. It's pretty easy job and not expensive at all.
    Quote Originally Posted by Hoyt Clagwell View Post
    I doubled up the seals. One of the Randy's said there was enough room. If you turn the seal around, you would be driving the socket against rubber. The brass side only shows on one side, the other side is covered in rubber.
    Apr 2020
    Ontario, Canada
    1999 Z3
    - - - Updated - -
    Thanks. I should've done it when I had my tranny out (identifies as it, that). I think the seal has started to leak a little since reinstalling the transmission last Spring.
  1. Rear tranny seal.
    By draccent in forum 1983 - 1991 (E30)
    Last Post: 10-31-2012, 09:21 PM
  2. Rear Tranny Seal leaking
    By tynashracing in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-25-2008, 01:03 PM
  3. Preventing 98 M Roadster rear window scratches
    By topdwnz in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-29-2006, 04:41 PM
  4. Replacing a Rear Tranny Seal
    By Tommy R in forum 1991 - 1999 (E36)
    Last Post: 07-27-2005, 09:46 PM
  5. Rear tranny seal e28 535i?
    By 535inVA in forum 1988 - 1996 (E34)
    Last Post: 03-02-2005, 03:12 PM
