Results 1 to 3 of 3
Thread: Bmw doesn’t go into gear when running and pedal is hard to push. Need help.
    Jan 2019
    Usa
    2003 bmw 325i
    I have a 2003 bmw 325i, one day I started the car and I couldn’t put it in gear no matter what I did. I pulled the transmission twice already and replaced the clutch, pressure plate, throw out bearing, master clutch cylinder, slave cylinder, and fully bled it. The second time I pulled it, the fingers on the new pressure plate where are pushed in for some reason, so I thought maybe I just received and defective pressure plate and the old one didn’t even look bad so I thought maybe the problem wasn’t even the pressure plate to begin with. But now it’s still doing the same thing, won’t go into gear and pedal hard to push. Any feedback would be helpful, thanks.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum. Hopefully help will be found here.
    88M3 AW 43k miles Project FS
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You could have a bad rubber hose that attaches to the slave cylinder. Did you see if the slave is pushing the clutch release lever towards the front of the car? Did you replace the pivot pin (part 6 in http://www.realoem.com/bmw/enUS/show...diagId=21_0093)?
  1. Replies: 9
    Last Post: 06-09-2016, 04:50 AM
  2. Replies: 2
    Last Post: 01-21-2015, 11:19 AM
  3. 2005 BMW 545i my Radio comes on But no sound come out the speaker need help
    By gegzs in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-20-2012, 05:39 PM
  4. Daytime running light out on my 5...I need help
    By Sephora in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-15-2012, 03:22 PM
  5. The BMW gods have spoken, my car runs in CMod.
    By krisko in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-14-2005, 01:40 PM
