Results 1 to 25 of 30
Thread: jack pad adapter, again
    Nov 2018
    Emmett, Idaho USA
    2002 Z3 3.0L roadster
    Sorry, don't mean to be beating a dead horse here, but did a search on jack pad adapter for the Z3. Yeah, there was talk about other models, and only one mention of a Z3 and that was with the factory jack. Looked on evil bay, & Amazon, which showed adapters for other models there was some for the Z4. Even Bavarian showed an adapter saying it would fit the Z3, but doesn't. Side note: you don't know who to trust anymore. Does an adapter out there fit our roadsters, or is it just BS?? I don't want to ruin my jack pads. TIA
    Dec 2017
    Plainfield Indiana
    1999 M Roadster
    I have a jack pad adapter that I purchased through Amazon, I think, but it's not z3 specific. Its got Burger Tuning on it, works fine for me. I think if the description states it'll work with BMW, you should be fine, Amazon is pretty good about returning if something doesnt work.
    Good luck!!
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,F700GS
    Reliable returns on Amazon? Definitely.
    Description reliability? No way.
    Anybody selling anything can claim compatibility whether it’s anywhere close or not and Amazon will list it. They used to be very good, but there have been more and more Chinese listings. Amazon has become another ebay without the bidding. Jack pads are a perfect example. I bought a set of jack stands and pads for my Z3 and ended up sending them back. There was zero fitup compatibility even though the ad stated they were for my car. Compatible would be something that matches up perfectly with the jack points on the car. Good luck finding that. The closest are the stands with the round rubber pad on top.
    They still have a great return policy, so use that to your advantage. If an order isn’t what you wanted, send it back. Don’t keep anything that doesn’t work as anticipated.
    Note, if it shipped from China and you don’t like it, return shipping cost can prohibit returning it.
    Oct 2008
    SFBay, CA
    Z3M Coupe
    The TMB Motorsports ones worked great for me.
    https://www.amazon.com/gp/product/B01M8HTXU7/
    Sep 2016
    Yulee, FL
    2000 Z3
    I was going to make some out of Delrin, but seeing how cheap those are I think my efforts are better focused making money with that time and simply buying that set with some of said money.
    Stubbornness is a virtue....
    Feb 2014
    allentown
    99 Z3M coupe/09 MCS
    Jack pads should fit almost all bmw and mini. I have an aluminum one and fits the Z, 335i and our Mini cooper s
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    I use a hockey puck under the front cross member and diff cover. It's the best $2 adapter I've used so far.
    Nathan in Denver
    1999 Z3 2.8 Coupe, 1 of 2, Manual Swapped, M Suspension & Brakes, M54B30 Manifold, Style 68's
    Denver, Colorado
    02 MRoadster / 435i
    Quote Originally Posted by s8ilver View Post
    I have used a hockey puck on the jack location for years and I even have a jack pad adapter which was given to me, but I never use it because the hockey puck works so much better.
    2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
    Jack pad adapters are not strictly required. As long as you are careful you would be totally fine without them
    With that being said there is also nothing special about the Z3 jack pads. Pretty much any BMW style jack pad - a round puck with a raised rectangle - will work fine
    Nov 2018
    Emmett, Idaho USA
    Well, that's Yankee ingenuity for you........all my research, and all it takes is a hockey puck.....who woulda thunk. If you build it, they'll buy it.
    Aug 2015
    Denver, CO
    Yep, just saw the CupFone by Weathertech, which is a phone holder that fits in your cup holder. $34.95.
    If I had one in my Z, I'd have to hold the phone and the CupFone so my coffee had a place to sit.
    https://www.weathertech.com/cupfone/...SAAEgJ9S_D_BwE
    Nathan in Denver
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by Z3 freak View Post
    ... did a search on jack pad adapter for the Z3... Does an adapter out there fit our roadsters... I don't want to ruin my jack pads. TIA
    So a jack pad adapter is something placed between a jack stand and the Z3 jacking pad. Why? How can a jack stand ruin a Z3's hard black plastic jack pad that is made for this purpose?
    BMW MOA 696, BMW CCA 1405
    Nov 2018
    Emmett, Idaho USA
    Quote Originally Posted by Vintage42 View Post
    I have seen pics on Pelican and videos on YouTube that have shown jack pads destroyed or missing. Don't know how or why, maybe like the rear substructure matter??
    Oct 2018
    West Bend, WI
    Incompatible design. The jack point on the z3 has a specific shape. Stands that have a deep V shaped top are designed for round steel undercarriage areas like axles. The shapes of those jack stands and the BMW jack points don’t match. Descriptions of missings jack point pads are very possibly caused by the wrong stands or jacks being used.
    A previous link is a good example of a perfect match:
    http://www.jackpointjackstands.com/
    Oct 2012
    Louisville, KY
    Perfection is good but expensive.
    There is no need to get expensive "compatible" Burger adapters that go up into the recess of the Z3 jack pads. The pad bears on the frame under the sheet metal, and a jack stand is fine as long as it pushes on the middle of the pad and does not touch the painted sheet metal rocker panel.
    Auto shops have raised Z3s for decades by putting their four lift arms under the jack pads.
    The Z3 jack pads snapped in until 8/97 and could get lost.
    https://www.ecstuning.com/b-genuine-...h/51718398169/
    After 8/97 they screwed in.
    https://www.ecstuning.com/b-genuine-...h/51718407559/
    Oct 2018
    West Bend, WI
    Good point. I wouldn’t spend the money on my link either. Maybe if I was a limited model service facility. Just pointing out one option for a perfect matchup.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Personally, my first choice is made by BendPak...
    (too much? )
    Oct 2012
    Louisville, KY
    Note that the jack in the Z3 toolkit is some kind of inclined screw with a rectangular probe of a tip that is made to fit into a Z3 jack pad. This is bad as it cannot lift a Z3 that has lost its snap-in jack pads. And it is useless for lifting any car but a Z3. I have not had to use it.
    I went to an import salvage yard and bought 4 scissors jacks out of old Honda Civics. They lift straight up, have a flat top, and only cost $10 each.
    If you want to rotate tires on one side of a car, it's convenient to use 2 of these jacks to raise that side. I have used them for that on my Scion and Forester. Z3s don't usually rotate tires.
    The little jacks are also useful for soft jacking with fingers, as in aligning bolts when changing shocks.
    Oct 2018
    West Bend, WI
    Quote Originally Posted by Randy Forbes View Post
    (too much? )
    There you go making us all jealous again ;-)
    Smart. How do you feel about stability having the car up on all four stands long term?
    Apr 2009
    Istanbul, Turkey
    Z3 M Coupe
    I produced and hard anodized my own jack pad adapters for my M Coupe
    @Tripfcr
    1998 M Coupe
    : (Euro S50B32), Estoril/Estoril/black, B&M SSK, 6Spd S6S-420G, Strong Strut, R.Forbes sub-frame kit & RE dual ear diff cover, Pro Ramp Variable Lock %75 LSD, Supersprint Race Headers & Resonators & DTM Cat-backs, Bilstein B6 Sport, BBS RC 301 & 303 8.5/10x18" wheels, Alcon Mono6 355x32mm Front & Mono4 332x32mm Rear Full Floating BBK
    Oct 2018
    West Bend, WI
    Very nice sir.
    Oct 2012
    Louisville, KY
    All the other mods to cemalakcal's Z3 are are also surprising. The ultimate coupe is in Turkey.
    San Jose, CA
    '11 335is vert, '01 Z3M
    Hey Randy, why are the tail lights on while up on the rack?
    Quote Originally Posted by sjdennis View Post
    There arent any light bulbs on that part of the light, reflector is shining because flash was on
    Apr 2009
    Istanbul, Turkey
    Z3 M Coupe
    @Tripfcr
    1998 M Coupe
  1. :: ECS Tuning :: ECS BMW Jack Pad Adapter - Now Available !!!
    By ECSTuningJames in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-25-2008, 02:56 PM
  2. :: ECS Tuning :: ECS BMW Jack Pad Adapter - Now Available !!!
    By ECSTuningJames in forum 1991 - 1999 (E36)
    Last Post: 08-27-2008, 09:19 PM
  3. :: ECS Tuning :: ECS BMW Jack Pad Adapter - Now Available !!!
    By ECSTuningJames in forum 1999 - 2006 (E46)
    Last Post: 08-27-2008, 05:22 PM
  4. Jack pad adapter and pads
    By BMWManiac in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2008, 01:49 PM
  5. wtb: e36 jack pad adapter
    By Anthony914 in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 11-19-2007, 06:58 PM
