Results 1 to 11 of 11
Thread: 96 850i electrical gurus needed / windows going down randomly
    Mar 2005
    Houston, TX
    '85 M635csi, '84 545i, 88 M3
    Hey guys,
    My friend has a 1996 850i that has us completely stumped. For the last 4-5 months we (me and mostly a bmw tech who used to work on these at the dealer) have been trying to figure out why the auto open convenience feature activates at completely random times. We have a 95 840i and a 91 850 parts/donor car and we have swapped and tried just about every module including:
    - general module
    - relay module
    - driver door handle assembly
    - door modules
    - and countless other items
    The windows/sunroof open at random. There is no rhyme or reason to it. Sometimes they will do down and after putting them back up, they will do down again in 5 minutes. Sometimes 3 days will pass until they go down. Sometimes you're driving and all of a sudden all everything starts opening. Sometimes it happens when the car is parked. If you disconnect the driver door harness the other windows and sunroof will still open. It doesn't help that there doesn't exist an ETM after 95 and I'm guessing there is one small minute detail that they changed in 96 that we haven't looked at yet?
    If there wasn't a need for the windows to go down to open the doors we'd just install a master bypass switch...but that's not the case.
    Wondering if anyone has heard of a similar problem? Tough to believe that the parts car would have the same issues as this one. Maybe related or unrelated but when you try to lock the car with the remote the car will lock, and immediately unlock.
    Thanks!
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    do the windows open first, then the sunroof?
    '91 850i 6sp (mint) (sold)
    Mar 2005
    Houston, TX
    So if the car is sitting (it just went down an hour ago) the car horn chirps like if you were unlocking the car and then the windows and sunroof open at the same time.
    Sent from my iPhone using Tapatalk Pro
    Sunny Cali,
    6.5 second 69 Camaro
    Sounded like a seized in the far right position or faulty door lock until you said the horn chirped, Never heard that one. The alarm factory?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, that certainly sounds like an alarm issue - either a rotten after-market one stuffed in somewhere or the OEM version fizzling out - often due to the rechargeable battery splurging out its innards...
    My BMW Repair YouTube Channel
    Mar 2005
    Houston, TX
    I'm pretty sure the problem persisted with the factory alarm disconnected...I'll try that again to see what happens.
    Also remember that we swapped the door lock assembly with one from another car with same issues.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    On second thoughts - could this be a problem with the remote locking receiver - or even a faulty key that is sending out the unlock signal. The receiver is in the rear-view mirror and can be disconnected after unlocking the car - that would certainly do it!
    Sep 2008
    Santa Barbara
    Passenger door lock switch.
    Dec 2009
    Sweden
    Blue 850/92 White 850/91
    A friend has had a similar problem, which was referred to a ground fault in the lower part of the a-pillar where the cables go to the door, may be an idea to check these cables and connections.
    Apr 2018
    Essex, UK
    '95 840Ci, '06 730d
    Sorry to hijack; Timm, where is this rechargeable battery? Is it part of the siren?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, it is in the same unit as the siren.....
  1. Replies: 9
    Last Post: 09-20-2010, 09:18 AM
  2. 96 328is electrical problem, need help
    By AU fan 06 in forum 1991 - 1999 (E36)
    Last Post: 01-21-2009, 02:54 PM
  3. Turn signal hell...electrics gurus needed!
    By biglittledog in forum 1983 - 1991 (E30)
    Last Post: 03-29-2007, 04:22 PM
  4. Wiring /Electrical Gurus - Need Some Taillight Wiring Help
    By ///MDex in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-22-2006, 05:43 PM
  5. Electrical gurus needed for advice
    By thisISlife in forum 1991 - 1999 (E36)
    Last Post: 07-29-2005, 06:47 PM
