Results 1 to 4 of 4
Thread: Considering to Purchase 2007 530i
    Sep 2016
    Phoenix
    E46 E39
    It only has 96k miles. I see the valve cover leaking. I am mechanically inclined and can work on engines.
    Besides the valve cover gasket set and bolts set (?), what other parts are needed to accomplish this job.
    Also, what else do I check to get this E60 in tip-top shape?
    Mar 2008
    Napa, Ca
    1987 M6
    At about 100K, we saw many major system issues on our 530XI including failures of AC compressor, starter, fuel pumps, transmission, air suspension, rear shocks. All those parts are common to E60/E61's, and cost for those fixes would be upwards of $20K at shop prices. We had an extended warranty at the time that covered the repairs, which was awesome, but on my dime it would have still been a lot of $ and labor. I'd say to verify if any of that major work has been done. Most importantly, the shifting should be totally problem free. Test automatic AND manual shifting on a long drive. If the tranny is good (that was an $8K fix), then flush fluid, and put on a new filter/pan. All the other issues would be a fix-as-you-go type of thing.
    I have read that at 100k the water pump is a looming issue you might want to go ahead and fix as a preventative measure.
    When you do the valve cover, check your coils and make sure there is no cracking on any of the rubber boots.
    Jose
    1987 M6
    Livin the dream!
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Quote Originally Posted by M5XTu View Post
    Take a look at the link below for a DIY tech article from our site on the valve cover gasket replacement.
    https://www.pelicanparts.com/techart...eplacement.htm
    888.280.7799 | 6am - 5pm PST
    Jan 2016
    Ca
    2001 525it
    You need to get a pre purchase inspection
  1. Considering the purchase of a gorgeous 2007 M6 w/SMG
    By huggy3613 in forum 2004+ (E63, E64, F06, F12, F13)
    Last Post: 03-14-2013, 11:58 PM
  2. Replies: 17
    Last Post: 09-14-2005, 12:40 PM
  3. What things should I consider before purchasing an E34 M5 (91-93)
    By BavarianBeast in forum 1996 - 2003 (E39)
    Last Post: 08-14-2005, 04:00 PM
  4. Just purchased 2001 530i few questions?
    By PrzwoH2O in forum 1996 - 2003 (E39)
    Last Post: 03-23-2005, 11:57 PM
  5. Fiancee considering the purchase of a 3-series - need advice
    By speedemn in forum 1999 - 2006 (E46)
    Last Post: 11-21-2004, 10:55 PM
