Results 1 to 10 of 10
Thread: Gas pump cutting out at a little over 3/4 tank
    Jul 2015
    Shoreline Wa
    M Coupe, A4 Avant , MGB
    When I fill up at the gas station now, the auto shutoff triggers at a little over 3/4 of a tank. Anyone have some insight as to why this might suddenly be happening?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    You probably have already tried setting the pump handle to the slowest fill-rate. My first guess is that your gauge is off. I'm not sure how to physically tell if your tank is full. I suppose you could make a dipstick.
    Jan 2016
    Ca
    2001 525it
    Fuel sender issues
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Run a couple of bottles of fuel system cleaner through the tank, to clean the resistance card in the sender.
    https://www.bimmerforums.com/forum/s...6#post30070776
    BMW MOA 696, BMW CCA 1405
    Jul 2015
    Shoreline Wa
    All give the fule system cleaner a try... I was wondering if it was moisture in the tank or something but the guage being wrong makes more sense, thanks.
    Dec 2016
    Baltimore, Maryland
    04 ZHP - 99 M Coupe
    Can you fool the auto shut off by readjusting the nozzle so it’s either deeper in or not as far in? Sometimes the way you have it in there can affect the auto shutoff
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Ring Rat View Post
    ... the auto shutoff triggers at a little over 3/4 of a tank...
    Quote Originally Posted by Wrench Turner View Post
    Can you fool the auto shut off by readjusting the nozzle so it’s either deeper in or not as far in?...
    I think he means the tank fills up but registers 3/4 on the gauge.
    Springfield, Ohio, USA
    1998 Z3 Roadster
    On a related note, it's interesting to do an internet search to discover how a gas pump nozzle stops. For my entire life, I understood it to be caused by back pressure, mostly due to my dad telling me that. It's not. It's caused by liquid gas being sucked into a little hole underneath the spout. That causes an imbalance of pressure from a venturi that moves a diaphragm which closes the valve.
    I never knew that hole was there under the spout and now I understand why the nozzle would not trip off when filling a gas can, but would trip when filling a tank.
    Jul 2015
    Shoreline Wa
    Ran a few fuel system cleaners through it over the past month and nothing has changed. If I fill it from when the low fuel light comes on, it takes around 10 Gal, and as mentioned the gauge only registers 3/4 tank. Is there possibly some vent in the filler neck thats blocked? Or is a faulty sending unit likely to read 3/4 tank at full tank, and read empty when there is 1/4 tank left?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    When my light has just come on, and I fill it up, allowing the automatic shut off, it often takes around 10 -11 gal (same as you). My guage says "full". I don't think I"ve ever put in more than 12, and that's after about 15 miles with the light on. (I just looked, and our cars hold 13.5 gal in the tank, so that means my car would have about 2.5 gal still in it when the light comes on. That would be a safe 40 miles, which seems about right.) ... So ... my theory again: your guage is wrong. ... I always reset the trip odometer, so I can monitor mileage with every fill-up. You can use it to check the gas guage.
  1. gas pumps cut off early
    By scooter086 in forum 1991 - 1999 (E36)
    Last Post: 07-16-2005, 12:59 AM
  2. more HP at the "gas" pumps.... lots of gains... i think?!?!?!
    By MMNJTWA in forum 1992 - 1999 M3 (E36)
    Last Post: 04-06-2004, 02:54 PM
  3. $700 for gas pump replacement ???
    By san_siro in forum 1991 - 1999 (E36)
    Last Post: 08-14-2003, 07:22 AM
  4. Gas pumps...
    By mens rea in forum 1992 - 1999 M3 (E36)
    Last Post: 04-27-2003, 12:47 PM
  5. Getting Raped at the gas pumps
    By E36 M Sedan in forum Off-Topic
    Last Post: 03-06-2003, 10:06 PM
