Results 1 to 2 of 2
Thread: EVAP and purge delete question
    May 2013
    Las Vegas, NV
    UFO
    I'm almost there with the turbo build.
    I had a few questions though in relation to the EVAP and purge valve on an OBD2 system.
    From what I have read is I can vent the EVAP valve to atmosphere (the one next to VANOS solenoid). What do I do with the purge valve and connection near the OEM location of the MAF? I plan on deleting all of this with a tune. I am curious what you all do with the hard blue line running into the engine bay. Also, when the car was bone stock I was getting strong fuel smells in the garage with a full tank. Bad charcoal canister?
    Looking for this information since I have the m50 manifold out. I have 2 taps. One 1/8" for failsafe and truboost, another for the BOV. How are you guys sourcing vacuum for the FPR? I'm contemplating JB welding the original FPR spot on the M50 mani for a more robust barbed fitting. I see some guys on here running 4 taps into the manifold and just curious why. Truboost calls for a T'eed connection from compressor housing, and that's what I'll be doing.
    Here is the blue line I am referencing.
    I think the valve on the left can VTA correct me if I'm wrong. What about the valve on the right?
    Almost there boys. Can't wait to drive this car.
    CURRENT: LimeRockParkEdition E92 M3 - BSM/Silverstone E70 X5M - AW/Dove E36 M3
    PAST: Techno/Dove E36 M3 - Techno/Dove E36 M3 - LSB/Black E46 M3
    Mar 2012
    Renton, Wa
    98 m3
    You would need to ask your tuner what he will tune out for you.
    Generally we delete all of these so you can just remove them.
    The blue line you can vent to atmosphere or tie into your intake tube pre turbo.
    The little oem barb on the bottom generally works but I usually plug it and add another “robust” barb in a more accessible location.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  1. EVAP Delete Question
    By TipsyMcStagger in forum Engine Conversions
    Last Post: 03-05-2015, 11:13 AM
  2. just when you though it's over. another fan delete question
    By fast4d in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2003, 09:30 PM
  3. Replacing front bumper + license plate delete question
    By LTrain in forum BMW Rides & Events
    Last Post: 04-11-2003, 10:04 AM
  4. Fan delete question
    By Dade in forum 1991 - 1999 (E36)
    Last Post: 01-29-2003, 04:06 AM
  5. Fan Delete Question
    By Rusty 904 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-20-2002, 01:54 PM
