Lights are in! I'm going to rig the blue lights to the fog light switch I think that way I can street drive the car without the police getting upset.
Also figured out my Surge tank location, lines and fittings come Monday. Thread post or YouTube video for the explanation of fittings/routing? What ya think
Getting closer.
Bulkhead fittings from vibrant, line from Russel.
Congrats on the build so far. just made it through your thread (still have to go back and look at the most of the video's). Started the same project 3.5 years ago, and am now starting to get back at it (just have had 4 major life events happen in between buying the car and today).
Thank you for the few idea's (like the dash). I suspect you did that to keep the factory ECM happy (for the speedo). Also who did your tuning?
Holy smokes, it has a bumper and tail light again!! Car will be at Detroit Autorama Next weekend too with my drift team "Bobby's Crew" if youre in the area come stop by!
I also have started on the "body kit" aka front splitter and side skirt extensions, heres a shot of the splitter for now,
Also, radium surge tank is almost completely plumbed, waiting on a few more fittings, I also went with the intank pump upgrade for the M3 hangar assembly with the adapter to -6AN
Not sure why, but your google drive links failed (your images). congrats on so much progress in just a little over 1 year.
try it now, I uploaded instead of drive links. and thank you! The car was "complete" enough to drive in roughly 3.5 months which is when I did my initial testing and then drove it the entire year last year pretty much as it was built making small modifications here and there. I have a ton of stuff I want to upgrade, but this thing absolutely rips, and to me not having a car to drive would have been a disaster.
Working on getting the center console more complete. I need to make some brackets to hold everything together but it's looking good.
Cleaned up the headlights today and finished up the fuel system!
If you haven't already hit that subscription button please!
https://youtu.be/DomI-DQQD7Y
Itching to get back at events! First one is June 12th at Kilkare speedway. Changing up the look a little as well for 2020. What's everyone else planning on attending?
Welp... Broke the first driveline component yesterday. Going to upgrade to a 1350 next and see how that goes.
Is that the Jags That Run 1310 to diff adapter that broke?
Yep, going up to a 1350 now with an adapter I'm going to make. I'm trying to do everything I can to not have to buy a new driveshaft. but if anyone wants to convert their four bolt flange to a 1350 then they'll have this adapter available haha currently the only adapter is from a 6 bolt 330 diff.
NICE!!! I think I have a 1310 on the back end of my driveshaft, but I think I could easily have that changed over by the shop that made it if needed.
I can pretty much tell you that's what I'd do... Maybe order two so I had a spare, and then throw some nice driveshaft loops on to minimize damage if another yoke comes apart..
I just ordered a 1350 and I'm going to machine an adapter so I don't have to buy a new input flange
But yes driveshaft loop definitely
I'm not clear on the setup, was your old rear u-joint a 1350/1310 hybrid, and the rear yoke on your driveshaft a 1350?
Excited to see how your adapted setup turns out!
Correct! There was no rear flange that would Mount to a 1350 and my 4 bolt. the driveshaft is essentially a 2015 Mustang driveshaft shortened. It has the 1350 on it already but I'll probably end up buying a new one of those because it got scraped up pretty bad. It just slides out of the tube and you can put a new one in. So basically I have to make an adapter plate because the 1350 adapter doesn't come in the BMW 4 bolt circle pattern. I already have the cad done for it I just need to get it machined after I do a test fit with a 3D printed one.
Finally got out to another event! Pocono this weekend. Anyone on here going to be there?
Wait, Fremont?? I was in the Bahamas working, so I don't even have my car running again yet... What driveshaft setup were you running?
Sweet!! Worked well I guess?
So that is a spicer 1350 yoke/flange/whatever, adapted via your adapter to the bimmer 4-bolt flange so that you can run a straight 1350 U-joint, correct? Or not...
