Page 4 of 9 FirstFirst 123456789 LastLast
Results 76 to 100 of 211
Thread: Supercharged Coyote E46 Build Thread
  1. #76
    Nov 2018
    Westland, MI
    2002 E46 325i
    Getting ready to weld !
  2. #77
    DeWitt, Michigan
    '97 540i/6, '97 328i
  3. #78
    BALTIMORE
    This thread makes me feel pathetic for giving up on making manifolds for my attempted 351 swap, as it seems like you've got less room than I had.
    Do the engine mounts need to be removed to R&R the finished headers??
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
  4. #79
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by jalopi View Post
    Currently I'm deciding if I want that too be an option or not. current design you would have to remove the engine mount on the side you are removing. however, I have thought about splitting the design into two pieces so that you could remove the header without removing the engine mount,which would make disassembly very easy but I don't think I would really need to do that that often if at all. . but honesty I've made it pretty easily to remove both so I don't think it's going to be a problem for myself if I ever have to remove them for maintenance or fixing something. Factory coyote headers on mustang require you to remove the engine mount to remove them as well so it's nothing special.
    And yes think about tight and then make it tighter lol.
  5. #80
    Nov 2018
    Westland, MI
    2002 E46 325i
    I've got to finish welding up the collector on this side and add the 3" V band flange. Then work on finishing up the driver side. Only 47 days left til the first event. It's going to be tight!
  6. #81
    DeWitt, Michigan
  7. #82
    Nov 2018
    Westland, MI
    2002 E46 325i
    Started messing with some wiring and was able to get the cluster lit up with the start button solid green which means it's ready to start!
  8. #83
    DeWitt, Michigan
  9. #84
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by tptrsn View Post
    That's so crazy!! This is really beginning to seem possible (in time).
    It has to be, I'm already signed up for Autocity lol
  10. #85
    Nov 2018
    Westland, MI
    2002 E46 325i
    Also, mustang fuel pump with some modifications fits in BMW assembly. I just have to run different hose. I'll be using a C5 regulator (58psi) to send fuel to the rail and return the rest into the tank like factory.
  11. #86
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by CoyotE46 View Post
    Doing this so I can run a simpler fuel setup engine calibration wise. Otherwise I have to run the entire mustang pwm setup which is sorta complicated.
  12. #87
    Nov 2018
    Westland, MI
    2002 E46 325i
    Sorry I haven't been posting, I have around 31 days left until my first event so I haven't been taking as many photos or video.
    Here's a couple photos if you have any questions just comment.
  13. #88
    Apr 2017
    NJ, USA
    '07 335I 6MT, '01 330i
    Yea, 30 days left for me too. I have much less to do than you, though! Dash looks SO cool in there, it fits pretty darn well. Do you plan on running any sort of heating/ defroster at least? Maybe a grid defroster slapped on the front?
    Keep it simple: half gutted '01 330i, welded diff, BC coils, SLR Super kit
  14. #89
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by awp235 View Post
    Yeah I'm going to have to get a defroster of some sort but for now that's the least of my worries. Worst case I get a 12v one and run it off the cigarette outlet
  15. #90
    DeWitt, Michigan
  16. #91
    Nov 2018
    Westland, MI
    2002 E46 325i
    Ordered the blowfish billet power steering mount. This allows me to use a s197 power steering pump (05-09) on the coyote. I have to get an different fitting for the high pressure line put on but it looks like it's going to work nicely.
    I also test fit the mustang radiator and lines and it fits inside the stock radiator support with some small trimming. Radiator hangs down a tad lower than stock but it's still above the bumper , I will have to see how low it is once the car is on the ground.
    Time to take the engine out one more final time to do billet oil pump gears, brake lines and clutch line, and then should be good to put it back in, finish the exhaust up and then fire it soon hopefully!
    Waiting on custom driveshaft as well from shaftmasters.
  17. #92
    Nov 2018
    Westland, MI
    2002 E46 325i
    Driveshaft fits perfectly! 3.5" aluminum rated at 900whp, hopefully won't break this thing.
    Getting radiator and supercharger LTR mounting figured out before I pull the motor tomorrow again.
  18. #93
    Nov 2018
    Westland, MI
    2002 E46 325i
    Engine back out for billet OPG's and additional header work. Mounted a T56 style clutch reservoir so I have separate brake/clutch reservoirs, added subframe reinforcement to the front and instead of putting them on the inside like normal, I put them on the top to raise my motor slightly because my current clearance from oil pan to power steering rack is very tight. Also started working on more wiring. I need to get some grommets to protect the wiring and I wish it took a picture but it actually got the Ford sync to load in the car on the dash haha.
    28 days til event, 25 ish til shakedown hopefully. And 7 days til startup! If I can manage to get the rest of the work done this week.
  19. #94
    Nov 2018
    Westland, MI
    2002 E46 325i
    Billet Oil Pump Gears done!
  20. #95
    DeWitt, Michigan
  21. #96
    Nov 2018
    Westland, MI
    2002 E46 325i
    Brake adapter welded up. Had to cut the stock MC linkage off and weld it to a nut on the chase bays booster delete MC. Bolts right up now.
  22. #97
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    that dash is too good.
  23. #98
    Nov 2018
    Westland, MI
    2002 E46 325i
    V bands welded on, test fit and now onto O2 sensor bungs. Then hopefully putting this back in the car this weekend if my brake line parts come in. It's much easier with the engine out of the car.
    Look at those baby headers haha, should still be good for 600HP at the wheels though.
  24. #99
    DeWitt, Michigan
  25. #100
    Nov 2018
    Westland, MI
    2002 E46 325i
    Bungs welded in I will only be running front O2 sensors so I only have to do them right at the collector. Tune will shut off the rears because I am running catless.
  1. E36 Ford Coyote Swap Build Thread
    By Fendbass22 in forum Engine Conversions
    Last Post: 04-18-2018, 04:31 PM
  2. E46 Widebody Build thread
    By jhstealth in forum BMW Rides & Events
    Last Post: 12-23-2016, 07:15 PM
  3. 600whp s52tu e46 build thread
    By hobbit382 in forum Forced Induction
    Last Post: 02-19-2016, 11:19 AM
  4. MY 2001 BMW E46 Build Thread
    By gorylewis in forum BMW Rides & Events
    Last Post: 02-11-2016, 11:34 AM
  5. MY 2001 BMW E46 Build Thread
    Last Post: 04-09-2015, 01:38 AM
