Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 75 of 280
Thread: Supercharged Coyote E46 Build Thread
  1. #51
    Nov 2018
    Westland, MI
    2002 E46 325i
    Driver side header mocked up as well as both engine mounts. I need to connect some of the piping yet obviously (link 7/8 and 5/6) but it's there for space claim. I made my own slim steering shaft as well because the stock one was hitting the driver side mount.
    I'll get these fully cut up and see where it sits from there!
  2. #52
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Looking fantastic! Glad you're making quick progress, May isn't very far away when you have to complete a project like this. Gonna be so sweet though!
  3. #53
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    I forgot you were making a thread for this. Looking super good homie. But we need more pics of the bearded guy holding the motor mount lmao
  4. #54
    Irwin, Pa
    97 M3, 12 135i
    I might've missed it in the thread, but what U-joint are you using at the steering rack? Putting an aftermarket column in mine and need to fab up a steering shaft to mate to it. Very cool build
  5. #55
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by Mark Aubele View Post
    Pmd!
  6. #56
    fairfax,va, usa
    2 E30s and a maxima
    Why you gotta PM? Im wondering the same thing. I also run an E46.
  7. #57
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by protomor View Post
    Either one of these will work. You need a 17mm 54 spline u joint
    https://www.summitracing.com/parts/fla-fr1963/
    https://www.summitracing.com/parts/fla-fr2563/
  8. #58
    DeWitt, Michigan
  9. #59
    Nov 2018
    Westland, MI
    2002 E46 325i
    Getting the headers figured out a little bit more. So far I can remove header without removing engine mount and engine in position, which is nice. Seems to have enough header clearance to mount eyeballing it for engine movement as well.
    For those wondering, the front cylinder feeding into the second (cyl 5 into 6) has two other cylinders firing before them, and this is how the factory Ford exhaust is designed as well.. so I should be okay with enough flow even though I'm feeding almost directly into it. So cyl 5 fires, then two more fire on opposite bank and then cyl 6. I couldn't really extend them any other way. It's super tight routing to work with.
  10. #60
    DeWitt, Michigan
    Hmmmm, somehow I think you're going to have enough power even if your header flow is a little less than optimal. Lol
    How about brighten up that artsy fartsy shot of the blower sticking through the hood so we can ogle that badboy.
  11. #61
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by tptrsn View Post
    Here's the shot
  12. #62
    DeWitt, Michigan
  13. #63
    fairfax,va, usa
    2 E30s and a maxima
    Quote Originally Posted by CoyotE46 View Post
    Both sides are 17mm 54 spline? What did you use for the shaft?
  14. #64
    Nov 2018
    Westland, MI
    2002 E46 325i
    17mm "D" shaft
  15. #65
    Nov 2018
    Westland, MI
    2002 E46 325i
    17mm "Double D" shaft I think it's what it's actually called.
  16. #66
    fairfax,va, usa
    2 E30s and a maxima
    Awesome thanks!
  17. #67
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Awesome thanks!
    Vorshlag sells the flaming river shaft for the e46 pre-assembled
  18. #68
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by Novablue454 View Post
    It's also $450
  19. #69
    fairfax,va, usa
    2 E30s and a maxima
    Yea but it's twice the cost of doing it myself https://vorshlag-store.com/collectio...shaft-assembly
  20. #70
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I mean with the parts linked its like $320. Flaming river sells the VS one for even more ($520!) the difference is the straight double d vs the collapsible shaft. The VS/FR is collapsible, so retains OEM safety.
  21. #71
    Nov 2018
    Westland, MI
    2002 E46 325i
    Video version of some updates if you want to watch.
    https://youtu.be/mv43FbgXzjo
  22. #72
    Nov 2018
    Westland, MI
    2002 E46 325i
    Passenger header started
  23. #73
    DeWitt, Michigan
  24. #74
    Nov 2018
    Westland, MI
    2002 E46 325i
    That first Y is looking real nice!
    Thanks! Taking my time so I hopefully don't have to worry about cracks later down the road.
  25. #75
    Nov 2018
    Westland, MI
    2002 E46 325i
    Tight!! Going to merge these into a collector then with a v band to then connect the rest of the exhaust to. I just have to break it apart and weld after I get the final piece in.
  1. E36 Ford Coyote Swap Build Thread
    By Fendbass22 in forum Engine Conversions
    Last Post: 04-18-2018, 04:31 PM
  2. E46 Widebody Build thread
    By jhstealth in forum BMW Rides & Events
    Last Post: 12-23-2016, 07:15 PM
  3. 600whp s52tu e46 build thread
    By hobbit382 in forum Forced Induction
    Last Post: 02-19-2016, 11:19 AM
  4. MY 2001 BMW E46 Build Thread
    By gorylewis in forum BMW Rides & Events
    Last Post: 02-11-2016, 11:34 AM
  5. MY 2001 BMW E46 Build Thread
    Last Post: 04-09-2015, 01:38 AM
