Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 226 to 250 of 280
Thread: Supercharged Coyote E46 Build Thread
  1. #226
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by tptrsn View Post
    Sweet!! Worked well I guess?
    So that is a spicer 1350 yoke/flange/whatever, adapted via your adapter to the bimmer 4-bolt flange so that you can run a straight 1350 U-joint, correct? Or not...
    It's actually a 1330. So my driveshaft has a 1330 that goes to the factory 4 bolt flange
  2. #227
    Nov 2018
    Westland, MI
    2002 E46 325i
    Axle said I'm out. Fixed up and ready to go for today at Pocono Screenshot_20200718-175655.jpg
  3. #228
    Nov 2018
    Westland, MI
    2002 E46 325i
    New motor mounts underway! Also changing up the header design to more of a longtube style. Rear end is getting tubed as well because of an incident from the end of the season.
  4. #229
    Nov 2018
    Westland, MI
    2002 E46 325i
    Using 3D printed header modeling cubes to mock up the pipes, this then can be translated directly to actual pieces. Each bend section is 22.5 degrees and matches up perfectly to the bend radius of the tubing purchased from aceraceparts. I'll post more once the collector is delivered and the rest of the pipe routed. This also gave me a chance to fix my header to steering shaft clearance issue I had.
  5. #230
    Nov 2018
    Westland, MI
    2002 E46 325i
    Update on headers
  6. #231
    Nov 2018
    Westland, MI
    2002 E46 325i
    Pic
  7. #232
    Nov 2018
    Westland, MI
    2002 E46 325i
    It's tight!
  8. #233
    fairfax,va, usa
    2 E30s and a maxima
    Just looking at that hurts my soul. Great fab work but that can't be fun to repeatedly test fit.
  9. #234
    Nov 2018
    Westland, MI
    2002 E46 325i
    Quote Originally Posted by protomor View Post
    Yeah this is where the 3D printed parts came in handy because I could easily snap them in and out instead of removing the whole thing, but now I'm at the point where I have to actual remove and install it to make sure it still clears everything. But it's way better than the first version of this exhaust that I have been running the last 2 years so it's worth the time!
  10. #235
    Nov 2018
    Westland, MI
    2002 E46 325i
    Update! I was able to remove the header with the engine still in the car, I just had to support it with a hoise and remove the engine mount and one of the steering rack bolts to swing it out of the way. This makes things waaaaay nicer if I have to remove a manifold for some reason at the track.
    Also, I have been using these 3D printed modeling cubes to minimize wasted material and some time. so far so good! I have to fix this last tube by adding one more bend, it doesnt enter the collector straight but it will be an easy fix.
  11. #236
    fairfax,va, usa
    2 E30s and a maxima
    looking good man! I design and 3d print parts so this makes me super happy. I've been printing body panel break away parts. So many uses for printing stuff!
  12. #237
    Nov 2018
    Westland, MI
    2002 E46 325i
    A little more progress, I need to fix a couple gaps but then it's ready to weld up.
  13. #238
    Nov 2018
    Westland, MI
    2002 E46 325i
    I unfortunately am not a professional welder, but these are definitely stuck together haha. This is going to definitely be an improvement for flow and of course sound. Onto the next side for welding
  14. #239
    Nov 2018
    Westland, MI
    2002 E46 325i
    Pic.
  15. #240
    fairfax,va, usa
    2 E30s and a maxima
    fooking mint
  16. #241
    Nov 2018
    Westland, MI
    2002 E46 325i
    It seems like it didn't move that much from welding, hopefully it still fits around steering shaft or the hammer has to come out. Clears engine mount and as you can see it's crazy how tight the steering shaft is if you can imagine it's spot
  17. #242
    Nov 2018
    Westland, MI
    2002 E46 325i
    Swapping out to metal engine mounts, the poly ones are super close to the headers and I don't want to chance it, even with a heat shield it doesn't make me feel happy with their rated temp of only 180deg.
  18. #243
    fairfax,va, usa
    2 E30s and a maxima
    135 ain't bad for that honestly. They look dinky but I'm sure they'll work.
  19. #244
    Nov 2018
    Westland, MI
    2002 E46 325i
    Had to modify the passenger side header... So I just ended up restarting. I have two pipes tacked, the other two mocked up with 3D print.
  20. #245
    fairfax,va, usa
    2 E30s and a maxima
    I might start selling the 3d printed header legos. Not sure if enough people want it tho. How's it compare to the real thing
  21. #246
    Nov 2018
    Westland, MI
    2002 E46 325i
    You can't sell them , it's patented by iceengineworks
    They're pretty dang close . Huge help on this project.
  22. #247
    Nov 2018
    Westland, MI
    2002 E46 325i
    Their parts are also injection molded way stronger than these, these locking tabs tend to break over time due to the 3d print not being as strong
  23. #248
    fairfax,va, usa
    2 E30s and a maxima
    Yea it's patented but there's room for competition. I've seen a few different models on thingiverse you can get but I hear you. And yea, they break after a while so they'd probably be for a hobbyist who just wants to make 1 header and never again lol. 3d printed parts don't have much elasticity. Even the TPU stuff. Although, TPU might be a better choice for this.
  24. #249
    Nov 2018
    Westland, MI
    2002 E46 325i
    Yeah Tpu would be too flexible, I used Petg for these to help it be a little more flexible, the model itself could use some Improvement. This is the model I found on thingiverse as well, I would probably thicken up some of the portions before I used these again though. For what I needed they worked out perfectly.
  25. #250
    Nov 2018
    Westland, MI
    2002 E46 325i
    Hey guys! Dayco posted an article on myself and a few other guys check it out please! I also completed Drift Indy's street league and placed 8th last weekend out of 32 drivers.
    https://www.daycoaftermarket.com/en/...e-drift-teams/
  1. E36 Ford Coyote Swap Build Thread
    By Fendbass22 in forum Engine Conversions
    Last Post: 04-18-2018, 04:31 PM
  2. E46 Widebody Build thread
    By jhstealth in forum BMW Rides & Events
    Last Post: 12-23-2016, 07:15 PM
  3. 600whp s52tu e46 build thread
    By hobbit382 in forum Forced Induction
    Last Post: 02-19-2016, 11:19 AM
  4. MY 2001 BMW E46 Build Thread
    By gorylewis in forum BMW Rides & Events
    Last Post: 02-11-2016, 11:34 AM
  5. MY 2001 BMW E46 Build Thread
    Last Post: 04-09-2015, 01:38 AM
