May have finally resolved the SAS but want to wait a bit before declaring success. Especially as I had a small problem with cyls 7-12 afterwards... misfires with cutoff. Oh wait, you are supposed to connect the accordion boot to the MAF and actually tighten it down?
Never mind...
Hopefully no other stupid mistakes... hence the wait.
2001 750iL DD74441
Stock
RIP: 2003 540iA Sport GS56111
H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
Damn it little things matter
New one
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
popped the valve body off of my replacement trans and noticed chunks in the fluid. now i'm on the hunt for another.
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
Registered a new key, now I have two that work!
I had only on olders style key, so sent the EWS and key off to RPM Motorsport. I ordered the older style key set. When I received it, it had two newer diamond style keys, two valet keys and the original key.
Turns out they couldn't get any older style keys, guess i'll have to make do with newer key...:P
Several weeks ago, I swapped 3 power steering hoses to stop a leak, just noticed fluid leaking again, time to source the leak.
Did you change out the old PS canister? These are cheap and the old ones normally leak.
Lets get the party started before it's my bedtime.
I'll second this. I need to replace mine at some point. It leaks a little around the cap. Put a new seal on the cap and even then, any time I take it off to check the fluid it's 50/50 whether it'll seal or if it'll slowly weep a little bit of fluid onto the outside of the reservoir.
Put on some new shoes. M5 wheels, Pirelli's. 19x9.5 & 8.5. 285/35/19 on the rear and they are Hugh. Rides nice. Got them for a song with tires almost new.
Better pics
I didn't replace the canister but I did replace 2 of the three hoses the go to the canister, I trimmed the third one to the SLS. The leak was located at the cooler lines adjacent to the radiator. Both of those hoses were replaced but the bolt needed to be tightened after a warm up and cool down.
Replaced the Rear C-pillar Seals as described in https://www.bimmerforums.com/forum/s...5#post29845255
And replaced the Center Split Armrest with the way obsolete Cell phone with a Euro Style Armrest
Added Daylight LED Lights to work area in the garage
"Vir, intelligence has nothing to do with politics!" - Londo Mollari & "You see but you do not observe." - Sir Arthur Conan Doyle - When the pin is pulled Mr Grenade is not your friend. - Unknown
Current Rides
- '96 E38 740il "007" or "the Green Beast"- Chassis 340k miles Engine & Tranny 50k miles
- '07 Toyota Tacoma 125k miles SR5 Prerunner in Texas it's just "The Car"
- '02 E39 525i 108k Miles Wife's ride "Ladyhawke"
Past Rides
- '80 Mercedes 240D "Bonnie Blue" - 415k miles still going somewhere... 0-60 in 5 minutes
- RIP - '91 E30 325i "the Tank" or the "pocket Rocket" 215k miles & '92 Toyota Camry LE V6 put 212k "Pegasus"
- Good Riddance - '85 Audi 5000 - Stupidest Dumbest buy I ever Made. I should've bought the 524td with the Cracked block instead!
- '80 Toyota Corolla - "the Stealth Machine" - Drove it like I stole it - You always miss your first one
They Don't want us Posting Links on the board but search Google/Amazon for "Sunco Lighting LED Utility Shop Light, 4 FT, Linkable Integrated Fixture, 40W=260W, 5000K Daylight, 4100 LM, Frosted Lens, Surface/Suspension Mount, Pull Chain, Garage – ETL, Energy Star" and it will take you right to it.
My Garage is nearly as bright as high noon without the heat and that nasty flickering effect of fluorescents and these things are a fraction of the weight so they can be suspended from the drywall and you don't have to find a stud
Current Rides
Past Rides
Who’s they?
https://www.amazon.com/SZGMJIA-Linka...-2-spons&psc=1
Good light is critical for sure!
Current Rides
Past Rides
Installed this gem in the L7. For $40 I'm using Bluetooth in a 22 year-old car. Love it.
StirlingM5
Alpina.ca
