TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
No wiring was needed unless you don't already have the rain sensor option. I used NCS but the best module to get is this one(6961141). I had trouble coding a different LCM IV...
This one did not work for me. I will try it in a friends 2000 M5... Follow this...
http://www.bimmerboard.com/forums/posts/752762
Installed a GROM Bluetooth USB in my E38. Integrates with my CD43 and with GROM's Dashlinq App and a Smart Phone even at 3x the Price of the other USB units you will be satisfied with none of the limitation of the cheaper generic Version
"Vir, intelligence has nothing to do with politics!" - Londo Mollari & "You see but you do not observe." - Sir Arthur Conan Doyle - When the pin is pulled Mr Grenade is not your friend. - Unknown
Current Rides
- '96 E38 740il "007" or "the Green Beast"- Chassis 340k miles Engine & Tranny 50k miles
- '07 Toyota Tacoma 125k miles SR5 Prerunner in Texas it's just "The Car"
- '02 E39 525i 108k Miles Wife's ride "Ladyhawke"
Past Rides
- '80 Mercedes 240D "Bonnie Blue" - 415k miles still going somewhere... 0-60 in 5 minutes
- RIP - '91 E30 325i "the Tank" or the "pocket Rocket" 215k miles & '92 Toyota Camry LE V6 put 212k "Pegasus"
- Good Riddance - '85 Audi 5000 - Stupidest Dumbest buy I ever Made. I should've bought the 524td with the Cracked block instead!
- '80 Toyota Corolla - "the Stealth Machine" - Drove it like I stole it - You always miss your first one
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Little things that matter
E90 mirror
Decided to do Bilstein B4 and Eibach springs plus full rear over haul. Guide rods and ball joint get here Wednesday. 750il Calipers and Rotors, rebuilt the calipers and have torn 3 new boot seals trying to install, I said eff it and took a break lol. Fun times ahead buddies.
Sent from my LG-G710 using Tapatalk
Trunk light
Had this laying around so I am trying it out.
What do you think?
Current Rides
Past Rides
Nobody knows the hidden secret to putting that boot seal on the 750 calipers?
I dunno, lots of lube and carefully slip them in?
Wait, wrong topic....
Replaced the Passenger Rear Full Window Shade (had a Rip and a Run in it) and switched out the Clip for the quarter window blind to one that was for post '97 while I was at it. In the Early '97s and prior the quarter blind had a hook that would hook into the clip. The Late '97s on had a hook like the vertical blind where the blind hooked to the hook... so to speak. BMW is very proud of those clips so I sourced my on Ebay out of Egypt for $5 each a couple of months ago and it took about 45 days to get to the US.
I already replaced the Driver side rear quarter shade and will change out that clip when I get some door panel clips as I broke about half a dozen tonight and popped over to Amazon and got 100 for $5 and free shipping
Current Rides
Past Rides
So no one was going to tell me we don’t have rear sway bar links on the 2001 740il? No one was going to tell me how time consuming changing all rear suspension and struts was going to be? No one was going to tell me the Jesus bolt touched the integral link bolt on its way to torque city? No one was going to tell me the rear strut bolts where hidden in Narnia?
Completed the Bilstein b12 pro kit changes and control arm changes on the 750, very happy with ride, stance and initial impressions are this will make a major difference in performance handling. 😀 old shocks where stuffed and had no rebound left at all, completed SLS delete etc as well of cause. Babies getting better
8EFC42CF-3DFC-41DA-8306-D5E2CBDD3AA0.jpg30DEDD3E-3F1B-4F6B-B00F-E16211FFD97E.jpg90023A6F-6FE0-46E7-A7F7-F9B11938F2E6.jpg9DB372A6-6713-4DFD-BB38-D1823E10FB9B.jpeg
1999 750i Individual
2012 F10 M5
2014 i3
Today was a good day! I replaced the following:'
1- Rear passenger window regulator
2- Akebono Brake pads all around
3- Stop Tech SS braided brake hoses all around
4- Removed old brake fluid (looked brownish) and pressure bled all around with Synthetic DOT 4
5- Replaced motor mounts (driver side fell to the ground in three pieces and they were BMW so most probably the original ones)
6- Replaced fuel filter (found out it was the original as it was dated from 5/99 and also had the vacuum line to the fuel pressure regulator broken)
Still pending are the brake rotors (got cross drilled and slotted from ECS Tuning), the flex disc and CSB that are being delivered tomorrow. And the rear driver's side regulator (finished too late and too dirty to work on it today! LOL)
Jimmy Moreno
BMW CCA 115551
1986 535i, Arctic Blue
2012 X5 XDrive 501, Sparkling Bronze Metallic
Pulled the pan on my replacement trans and noticed some things...
Sent from my SM-N950U using Tapatalk
Ohh you knew I was talking about the mounting bolts, I even put everything back and was like "ooohh whats this shiny clip thingy doing here thats supposed to be on the ball joint"?
Car drives better and feels so tight, now I can feel that there are bumps in the road, even the small humps I would glide over resonate all in my seat, its not uncomfortable, just noticable.
