Page 2 of 16 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 390
Thread: 2019- What did you do to your ride today?
  1. #26
    Jan 2019
    Houston Metro
    '96 740 iL, '02 525i
    Easy Fix for washer like above pump through Hood Grommet
    Researching why the Washer Motor worked but no spray. Found that the line between the upper line from the pump through the grommet in the hood to the to the lines to the intact Jet line was just disintegrating. Spliced in rubber black irrigation hose using existing clamps and a few zip ties and two of the largest connectors to maintain the same pressure. Fix Time 30 minutes, troubleshooting and trying not to break anything 30 minutes. Then the moment when I pushed the Grommet through the opening of the hood only to spend another 90 minutes trying to get it back out and then back in properly without damaging it!
  2. #27
    May 2013
    Rochester, NY
    2001 740i Sport
    New center link, idler arm and tie rod ends, new motor and trans mounts, and a new set of camber plates (Ground Control E39 M5 plates) over the last 2 weekends. Car goes in for alignment tomorrow morning.
  3. #28
    Apr 2009
    Land O Lakes, FL
    1986 535i, 2012 X5 50i
    Just did this past Saturday the transmission service with the Filtran filter. Oil that came out was dark brown, not burnt but definitely showing its age. Only about 3.75 quarts came out so it was low and it took about 5 and a half to fill it up. Getting the pieces of old gasket of the trans body was a pain! Took advantage and also change the transmission mounts. One was already on 2 pieces and the other was starting to de-laminate but both were very compressed. Tran
    Now car shifts smooth without the hesitation between gears!
    Jimmy Moreno
    BMW CCA 115551
    1986 535i, Arctic Blue
    2012 X5 XDrive 501, Sparkling Bronze Metallic
  4. #29
    Jul 2016
    San Diego
    1998 E38 750iL
    Installed my new wheel wrapped with leather from Redline Goods. Full details to come in my build thread.IMG_20190205_105054.jpg
  5. #30
    Sep 2012
    CT
    replaced ambient temp sensor... $15 and took 5 minutes... nice to know its not actually -40 degrees out every day!
  6. #31
    Jan 2019
    Houston Metro
    Figured out why my trunk would only open with the Key.
    Thought it had something to do with the actuator not unlocking
    What it really was is the alignment of the locking mechanism and the trunk lid. Used my phone and videoed the trunk locking and unlocking discovered that the cam on the Trunk lid power lock drive (67338352202) was not engaging the lock.
    Drove me nuts for several weeks until I thought, "Hey dummy put a camera in there and see what is going on."
    Once I had that figured out it was just loosening the screws on the Trunk Lid Power Lock Drive and sliding it over about 3/16" so the Cam on the drive would engage the latch release. Also making sure the lid was adjusted "just right" After about a bazillion small adjustments it worked. Trunk lid is off by about 1/8" lateral and vertical from one side to another but seals. (it was that way before I started, so I don't know if the car previously had a fender bender or what) I'll take it and work on that another day. I did fiddle with the bump stops but that only messed up the alignment even more.
    Also If I ever get locked up in the trunk of a 740 I'll know to just manually turn that cam or rip out the liner and grab the rod from the lock to the catch.
    Next.....!!
    "Vir, intelligence has nothing to do with politics!" - Londo Mollari & "You see but you do not observe." - Sir Arthur Conan Doyle - When the pin is pulled Mr Grenade is not your friend. - Unknown
    Current Rides
    • '96 E38 740il "007" or "the Green Beast"- Chassis 340k miles Engine & Tranny 50k miles
    • '07 Toyota Tacoma 125k miles SR5 Prerunner in Texas it's just "The Car"
    • '02 E39 525i 108k Miles Wife's ride "Ladyhawke"
    Past Rides
    • '80 Mercedes 240D "Bonnie Blue" - 415k miles still going somewhere... 0-60 in 5 minutes
    • RIP - '91 E30 325i "the Tank" or the "pocket Rocket" 215k miles & '92 Toyota Camry LE V6 put 212k "Pegasus"
    • Good Riddance - '85 Audi 5000 - Stupidest Dumbest buy I ever Made. I should've bought the 524td with the Cracked block instead!
    • '80 Toyota Corolla - "the Stealth Machine" - Drove it like I stole it - You always miss your first one
  7. #32
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    Excellent out of the box thinking with the camera action!... I would have shut myself in the trunk with a flashlight,
    never to be seen again....
  8. #33
    Jan 2019
    Houston Metro
    Replaced the Underhood and the Internal recirculating Air filters on my '96 E36 740iL. The Passenger side took longer due to the learning curve than the driver's side was pretty quick but couldn't get the panel screw in the middle so... that was a bit frustrating! Man, they were full of gunk! Ewwww!!!
    Now That I've successfully practiced Yoga in my E38 and My Chiropractor will say that I'm not supposed to bend that way as he puts all my ribs and vertebrae back into alignment LOL
    Current Rides
    Past Rides
  9. #34
    IL
    2000 740i sport
    Quote Originally Posted by Aitch View Post
    Can you snap a few shot of the vinyl wood wrap you used?
    Sent from my SM-N960U using Tapatalk
  10. #35
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    I did this today. Was bummed I missed the moment by one mile but oh well, I'll do it again in another 10k miles...
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  11. #36
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by purplecty View Post
    Yes, I don't have any right now but I can get more interior shots.
  12. #37
    Jan 2018
    Texas
    1999 BMW 750il
    I swapped The thermostat, fan and fan clutch, vent hose from the water pump, egr air pump hoses and bled the coolant.
    It was a job well done and wasn't too bad, except for a wrong cover for the engine below the intake pipes, causing me to have the "Wong" vent pipe.
  13. #38
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    Quote Originally Posted by clarkitect View Post
    Catch it in 2,221 miles for 222222.
    '01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
    '99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
    '84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
  14. #39
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Did my rear brakes (rotors and pads) and realized why I had difficulty putting on the winter shoes. Apparently I have 15mm spacers all around. Ummm... what?
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
  15. #40
    Rutland, Vermont
    Quote Originally Posted by 740iSport303 View Post
    YES! And be savvy enough to reset the trip odometer at 222,000...
  16. #41
    NYC
    99 IL/13 SXT/04 Audi A4
    Wash it
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  17. #42
    NYC
    Got a DINAN MAF To go with my DINAN CAI and also got DUDMD tunning for the MAF
    El Cid 1999 IL
  18. #43
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Swapped my mpars on from my project car.
    Sent from my SM-N950U using Tapatalk
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  19. #44
    Feb 2012
    Prague, Czech Republic
    E30 325i; E38 740i
    I put the roofracks on + the roofbox + Alpinas 20" with brand new winter tyres on. 740i ready for mountain rides
  20. #45
    Dec 2009
    Dallas,TX
    ^looking good.
    Picked up a set of E63 M6 Mufflers, just waiting for my x-pipe to get here.
  21. #46
    Jan 2018
    Lithuania
    '97 BMW 725tds e38
    Replaced the windshield wiper blade's! And tomorrow he'll finally get a much needed wash.
    BMW 725 tds e38 2.5l '97
  22. #47
    Carmel in.
    95 740i, 92 ACSchnitzer
    Quote Originally Posted by Sabreslight View Post
    ^looking good.
    What do E63 mufflers do for your car? Sound, weight, ???
    Lets get the party started before it's my bedtime.
  23. #48
    Dec 2009
    Dallas,TX
    Quote Originally Posted by gaspump View Post
    Sound, that combined with a xpipe makes a pretty good sound, TXDarth here did it, that's where I got the idea. Plus I got them super cheap.
  24. #49
    IL
    2000 740i sport
    They are perfect for the M62. I recommended them to Roger after a buddy of mine put them on his N62 545 when converting it to true duals. You won't be disappointed...
  25. #50
    Dec 2009
    Dallas,TX
    Awesome, I got the set for $60 so I really can't be disappointed lmao
  1. Nice Ride Today
    By Hank in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-21-2004, 04:36 AM
  2. washed my ride today.
    By ///MacDaddy in forum BMW Rides & Events
    Last Post: 09-03-2004, 12:58 AM
  3. Many thanks for the rides today at GGF
    By einhander in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-06-2003, 02:46 AM
  4. OT:Yo Kevin (Kevlar) how was the ride today ;)
    By AMG-ETR in forum 2001 - 2006 M3 (E46)
    Last Post: 07-29-2003, 03:33 PM
