BAVToys
Results 1 to 3 of 3
Thread: E92 328i xenon headlight issues after new bulb and ballast
    Jan 2019
    California
    E92 328i
    There is no power to pin #3. Already tested on drivers side and there is power but none on passenger side. Can i splice the cable from drivers side and run a cable to passenger side so that my xenon headlight can turn on ? Or will that fry my footwell module ? Im trying to avoid buying a module if i could.
    I connected both headlights to drivers side and both turn on great, just that passenger only turns on halogen h8 light and D1S doesnt turn on. Any help is much appreciated.
    Jan 2016
    Ca
    2001 525it
    You need to pull both headlights swap the modules then see what happens. If the othe headlight acts up after the move then replace the module it will have to be coded to work
    Jan 2019
    California
    E92 328i
    Just what i was fearing to do. Thank you for your help.
  1. Xenon headlight issues
    By daasfather in forum 1999 - 2006 (E46)
    Last Post: 08-25-2009, 09:17 AM
  2. license plate light won't work after new bulb...
    By tiddlydee1289 in forum 1991 - 1999 (E36)
    Last Post: 09-19-2008, 07:24 PM
  3. 1999 328i rear brake noise after new brake job.
    By rami737 in forum 1999 - 2006 (E46)
    Last Post: 08-21-2006, 01:55 PM
  4. headlight out with new bulb
    By BADASS_R6 in forum 1991 - 1999 (E36)
    Last Post: 05-27-2005, 02:47 AM
  5. HELLA CELIS xenon headlights - foggy after heavy rain
    By gabcris in forum 1991 - 1999 (E36)
    Last Post: 05-28-2004, 02:14 PM
