Results 1 to 5 of 5
Thread: E36 Subframe Reinforcement and PF Bushings
    Jul 2006
    Raleigh, NC
    E36 Track Rat, E46 M3 DD
    I'm working on getting my cleaned up subframe reinstalled along with all new ball joints, bearings, etc. Condor Speed Shop Reinforcements are getting welded in tomorrow morning. Either I'm over-thinking this, or I have incorrect parts, can't tell which. I've googled, and googled, and there are hundreds of posts about rear subframe bushings, many of which are conflicting.
    1. The Condor Reinforcements are just flat plate, not contoured like some. That puts the front mounting stud " hex nut" on the bottom surface of the reinforcement plate. If I put the PF washer on the top and the bottom of the bushing, the top washer, will just be bearing on the "nut" not bearing on the reinforcement plate. That seems strange to me. Normal?
    2. The rear PF sleeve has a larger ID than the front sleeve, despite the front stud and rear bolt having the same OD. The ID seems too big for the mounting stud, and there is significant play. Every stock photo of the PF kit I can find, show the two different sleeve IDs. Seems odd to have this much slop in the rear sleeve. Pic Below. Normal?
    Thanks,
    Glenn
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Quote Originally Posted by wake74 View Post
    Should we assume that yours is a non-M E36?
    Normal. The reinforcement plate (add-on for non-M E36 chassis) strengthens the chassis floor in the area where the mounting stud is threaded. As designed by BMW the hex formed into the stud accepts the vertical load from the subframe.
    Normal. The front mounting studs align the rear subframe and the enlarged rear holes allow for some latitude in assembly. In a perfect world you might hope that everything might just line up perfectly without that, but...
    Neil
    Jul 2006
    Raleigh, NC
    Neil - Thanks for the detailed answer. Much appreciated. Yes, the chassis is a nonM E36 sedan. Although I recently scrapped out a too cheap to pass up M3, so the nonM track car is getting all the M3 components currently, including diff, subframe, spindles, etc. Welder stopped by this morning and welded them in. Did a good job. I have a small MIG, but I didn't want to deal with the overhead welding given that I weld about twice a decade, and I am horrible at it.
    Fort Wayne, IN
    I resemble that remark! Made a rule for myself only to do minor convenience welding, nothing structural. Fortunately I have a skilled friend...
    Neil
    Vancouver, B.C., Canada
    '97 M3
    FYI Remove the black tar sound deadening under the back seat bottom and up onto the trunk forward floor. You may find popped spot welds and cracking in that area, especially on the passenger side. It’s a common failure point that is hidden and makes for a sloppy subframe forward attach point. I’ve put a lot of effort into investigating and resolving the issue.
  1. Replies: 8
    Last Post: 08-24-2016, 09:44 PM
  2. E36 Subframe reinforcements. Who wants em?
    By protomor in forum Middle Atlantic - US
    Last Post: 01-15-2010, 10:00 PM
  3. Optimal installation method for E36 subframe reinforcement to prevent rust?
    By bennyfizzle in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-31-2009, 01:18 PM
  4. E36 Subframe Reinforcement Plates
    By m50 e36 in forum Suspensions, Springs & Shocks
    Last Post: 04-23-2009, 11:08 AM
  5. E36 subframe reinforcement. If you can do this for me I'll give you lift time.
    By SQ Bimmer in forum California sponsored by Avus Autosport
    Last Post: 06-10-2005, 03:34 PM
