Results 1 to 11 of 11
Thread: A little flop when I steer
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    98 Z3M 111k miles. Recently and suddenly, my car has developed a small flop when steering around the center position. Tires are good, Koni shocks are new. The car does not drift in either direction, but it does now follow road irregularities just a little bit. By "flop" I mean that it feels like the wheels shift from right to left (or left to right) without input from me. It's hardly noticeable, but I think an indicator that something will soon need replacing. Before I lift it and start looking around, does anyone have any suggestions for what to look for and how to look/inspect? (I'm hoping someone will tell me to put new control arm bushings in and everything will be okay. I fear I need new, expensive-M, control arms.)
    Tie rods? Bring it by my shop in Mesa next week sometime and I can take a look. No charge for a fellow Z3er
    PRICE CUT on ALL FABRICS
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Quote Originally Posted by BimmerBreaker View Post
    Best offer I've had in years.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Another potential cause could be that bushing in the steering shaft is worn.
    https://www.ecstuning.com/b-genuine-...y/32311092644/
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Quote Originally Posted by scenturion View Post
    That part number is for the shaft assy, that has 2 u-joints and that rubber coupler. Yes, I suppose there could be a problem there. I wouldn't think the coupler; that would produce more of squishy feel. Maybe one of those u-joints? We'll see what Graham, (BimmerBreaker), has to say.
    My name is Graham lol
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Hey, I knew that! I was doing 2 things at once. My apologies....................
    Sep 2012
    Nebraska
    1998 M Roadster,'07 328i
    Guys do you have an update on what you found?
    Just curious, I have the same issue. I *think* mine is in the rubber bushing on the steering shaft.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Not yet, will post when I know more. Probably within the next couple of weeks.
    Sep 2012
    Nebraska
    Thanks for the update, I’ve got a used shaft coming and I think I’m going to try Saneesh’s idea of using the E30 steering giubo. I am going to replace the rest of the front suspension this spring when it gets nicer outside.
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Quote Originally Posted by sydjai View Post
    If its the type of thing that happens over bumps aka bumpsteer look at control arm bushings. My Z3 would dart around over any bumps but then I got one of those front suspension refresh kits from FCPeuro and some upgraded poly E36 M3 offset control arm bushings and its night and day difference. Car stays straight over big bumps now and is much easier to keep under control. Stock control arm bushings may have fixed the problem also, but I figured it was a nice upgrade.
  1. A little play in the steering
    By Jacksone30 in forum 1983 - 1991 (E30)
    Last Post: 03-07-2011, 06:32 AM
  2. A little color for the steering wheel
    By sirius600 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-20-2007, 02:18 AM
  3. steering wheel is a little off-center to go straight
    By Dima in forum 1992 - 1999 M3 (E36)
    Last Post: 04-16-2003, 05:36 PM
  4. Replies: 2
    Last Post: 09-27-2002, 08:01 PM
  5. Steering wheel a little off center when driving straight. Alignment?
    By ultim3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-03-2002, 08:09 AM
