Results 1 to 5 of 5
Thread: electric water pump fuse (Fuse 23) keeps blowing.
    Feb 2013
    Pinole, CA, US
    1998 BMW 318ic
    Hello everyone. I have very little experience with E60 (My older car was E36, which I am familiar with a bit) and am trying to diagnose an engine overheating problem.
    A month ago, I got the engine overheating error (drive moderately message followed by stop engine message). Upon quick diagnosis I realized that fuse 23 in the glove box was blown. I knew there must be some reason why it blew, but for the time being it seemed I solved the issue. I drove a bit for a few weeks and now it is blowing again. It is not intermittent anymore and the fuse 23 blows immediately after I start the car. Can you give me some directions where should I start?
    Is it possible there is a short in the connector at the electric pump resulting in short? Is the pump reachable from the top? My driveway is sloped, so I am not sure if I can access the car safely from the bottom. Thanks!
    Feb 2013
    Pinole, CA, US
    1998 BMW 318ic
    Quote Originally Posted by 98318icRed View Post
    I forgot to mention the details of the car. It is a 2007 525i with N52 engine. Thanks.
    Mar 2008
    Napa, Ca
    1987 M6
    You have get underneath to access the pump. I would agree with disconnecting the pump, to verify if it is wiring, or pump itself.
    Jose
    1987 M6
    Livin the dream!
    Jan 2016
    Ca
    2001 525it
    Electric water pump is most likely failing the drive moderately and over heat message point to the water pump, replace the thermostat also there bolted together. There's probabaly a fault stored for water pump
    NE Oklahoma
    E60 530xi - E53 4.4
    Quote Originally Posted by jclausen View Post
    With that fault code show up with normal OBD scanner?
  1. fuse 23 keeps blowing
    By onsitecom in forum 1983 - 1991 (E30)
    Last Post: 02-14-2011, 07:53 AM
  2. Vert fuse 5 amp keeps blowing out
    By cazador64 in forum Convertible Questions
    Last Post: 08-16-2008, 10:31 AM
  3. Fuse 30 (lighter) keeps blowing
    By tabhasg in forum 1991 - 1999 (E36)
    Last Post: 12-06-2007, 01:57 AM
  4. fuse for blinkers keep blowing, help!
    By VNG704 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-21-2007, 02:40 PM
  5. Fuse for fogs keeps blowing
    By mahmudb in forum 1991 - 1999 (E36)
    Last Post: 12-05-2006, 08:53 AM
