Results 1 to 25 of 25
Thread: Shifting issues on my M
    Oct 2018
    Surfside, Fl
    1998 BMW Z3M Raodster
    Hello,
    I started having a hard time shifting into 1st gear (from a stop) after driving the car after about half hour. Unlike others in this forum that experience hard shifts when the car is cold, the opposite is happening for me. Can anyone shed some light on this issue?
    clutch line
    PRICE CUT on ALL FABRICS
    Oct 2003
    Seattle
    99 M3
    I find that if I pump the pedal ~20 times that my shifting can improve.
    Don’t know IF that is cleaning the input shaft under the disk OR bleeding the slave, but it seems to work.
    Jan 2016
    Ca
    2001 525it
    We have had good success with the factory I think it's called sl2 BMW gear oil, we used to use redline, but the BMW oil seemed to work better
    Mar 2016
    Detroit
    Z4M Coupe
    Here’s my checklist is order
    1) trans oil
    2) clutch line
    3) shift pins
    Springfield, Ohio, USA
    1998 Z3 Roadster
    If the shifting problem goes away with the engine turned off, then the problem is the clutch hydraulics. If not, it's in the transmission and/or shift linkage.
    Kent, Ohio
    1998 M Roadster
    Classic clutch line symptoms. Check out this thread.
    Oct 2018
    Surfside, Fl
    This appears to be the issue since it shifts perfectly with engine off. What is the best transmission fluid to use to circumvent this issue? Thanks
    Quote Originally Posted by Blacklane View Post
    Sep 2018
    St. Louis, MO
    2001 BMW Z3 M Roadster
    Amsoil 5w30 and a UUC line fixed mine.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by edoinfl View Post
    If it shifts fine with the engine off, as Blacklane said, the issue is in the clutch hydraulics not the transmission hydraulics. You need to replace the rubber clutch line, replacing the transmission fluid will not address the problem. That being said, AMS oil is a good product for our transmissions and you can't go wrong changing to it--follow this thread.
    Hard to shift only after warmed up is usually clutch line. After long drives, old worn clutch lines start to bulge instead of passing the hydraulic fluid through properly. Replacing the clutch line with new, preferably braided steel, will prevent that issue in the future.
    Oct 2018
    Surfside, Fl
    Thanks for all the good advice and comments. I saw the ECS (Exact-Fit Stainless Steel Clutch Line). Does anyone have any comments on this clutch line or is there one that is a better option for the M?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    After checking them out, that's the one I bought (still haven't put in on, hope to in the next week)
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by BanjoDave View Post
    Amsoil 5w30 and a UUC line fixed mine...
    I wonder which one did the fix, or if one could not have done it without the other.
    BMW MOA 696, BMW CCA 1405
    Mar 2003
    Willis, TX USA
    98 MZ3, 01 325iT
    Clutch line. Mine does the same thing. Replace the line and flush the system. It’s in my “To-Do” queue.
    BTW, the is another on-going thread about this issue.
    George Roffe
    98 M Roadster
    01 325iT
    Texas
    '02 Z3, '09 Mini
    Here's another option that I used, Bimmerworld:
    https://www.bimmerworld.com/BimmerWo...-536-0002.html
    However, the E46 video on that page is absolutely NOT indicative of how much of a pain this is to do on the Z3.
    I wasn't having shifting problems, I just wanted to try to get rid of some of the driveline 'clunks' when I push in the clutch pedal at low speeds. Anyway for anyone interested in what is involved, I wrote a lot of detailed notes in this thread:
    https://www.bimmerforums.com/forum/s...-Hard-to-shift
    I have a 2002 3.0, so one crucial connection is a little different than your car. In one way mine is easier since the clutch line female end has a hex head built into it to get a wrench on, but in another way my car is more difficult since the bracket thingy the line connects at has only a hole, rather than a slot like on your car so you can just slide the line out and work on it outside the bracket.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Shifting problem solved ... It was the stupid clutch pedal stop. It was in the care when I bought it, about 1" thick. It just occurred to me to take it out. Lo and behold, all shifting problems gone: shifts like a new car should. So, does that tell me my stock clutch line it expanding under pressure? I ask because it seems many have used a pedal stop without shifting problems. I've got the ECS SS line, just havent' put it in yet.
    Kent, Ohio
    1998 M Roadster
    Well, if it worked fine with the stop in place until just recently, something changed, and that something is likely the clutch line expanding, so probably yes.
    Sep 2018
    St. Louis, MO
    UUC line lifted my clutch pedal engagement point. Amsoil cut the notchiness and made it go into first a LOT easier.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by zellamay View Post
    Could also be an indication that the clutch disk is reaching end of life.
    Oct 2018
    Surfside, Fl
    What is the recommended viscosity if I want to go with Amsoil. Hearing a lot of good comments about it. Thanks
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The transmission was designed to use Dexron3 ATF. If you talk to Amsoil, they will tell you they do not have a compatible MTL for this box. They are correct in that regard, but their ATF works fine. I personally use the cheapest house brand Dex/Merc ATF and change it every ten years or so.
    /.randy
    Feb 2012
    MN
    1997 z3 roadster
    Lot to read in this thread linked below. There are many comments about the higher viscosity especially when cold. I live in Minnesota but store my Z during the winter. The Amsoil is as notchy as the ATF when cold but is smooth in less than a mile of driving.
    Amsoil MTF 5w-30
    It's a Hybrid--Burns Gas and Rubber
    Oct 2018
    Surfside, Fl
    Anyone know how much transmission fluid I need? I'm decided to go with Amsoil 5w30. Is one quart enough? Thanks
    1998 Z3 Roadster
    You need 2 quarts for the transmission.
    I used AMSOIL Synchromesh 5w30.
    https://www.bimmerforums.com/forum/s...smission-Fluid
    BTW the differential also requires 2 qts of 75w110.
  1. Tramsmission Shift issue 4th - 5th
    By JonC6367 in forum 1988 - 1996 (E34)
    Last Post: 05-02-2006, 06:24 PM
  2. '99 328is shifting issues
    By JSF252 in forum 1991 - 1999 (E36)
    Last Post: 08-10-2005, 01:51 AM
  3. Shifting issues. Need help bad
    By Justbimmering in forum 1991 - 1999 (E36)
    Last Post: 03-09-2005, 06:12 PM
  4. Shifting issues
    Last Post: 03-09-2005, 01:26 PM
  5. shifting issue... any ideas?
    By kem in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-28-2005, 12:16 AM
