I realize this subject has been covered. I thought it was my scanner that was not properly working so I took my car to an independent technician that I trust. Apparently I still have the same problem...passenger air bag issue. (see enclosures) I checked the plug connections...appears okay. No broken wires. So I need some advice/help on what can be done to resolve this issue. Thanks in advance for your help. You may need to click on each enclosure to open the page.
That last image is upside down. Did you take the airbag connectors apart and look at the pins and sockets?
On a side note, it is an airbag...battery disconnected and let it sit before working on it to insure the airbag firing circuit caps bleed down.
