Results 1 to 13 of 13
Thread: Real 911 Turbo Big Red Front Calipers
    Jul 2006
    Hanover MA
    '11 Golf TDI+Porsche 996
    Removed from a 2006 Turbo Carrera that was wrecked with 20k miles. These are in great shape.
    The number are 996.351.429 996.351.430. They are improved over the 425/426 earlier versions.
    $600 shipped.
    I believe these are the correct ones for the RallyRoad brackets but please confirm with them!
    Full gallery here
    https://imgur.com/a/ueHp0EQ
    I own mostly junk. Except the Porsche, that's kind of cool.
    All the motorcycles are trash which you can read about at
    http://oneguytwowheels.blogspot.com/
    I'll update it eventually
    Thansk
    gilbert,Arizona
    95 M3 Coupe
    I can verify the performance of these brake calipers as I have these on my E36 M3. They are amazing brakes, very responsive. You will however need to run 18s as a minimum wheel size. You can NOT fit them under 17s. Same goes for the E46 M3 as well and I would imagine all e36 and e46 models. I built my own bracket, but if you are not comfortable doing so you can contact Rally Road via email and they can cut brackets for you. It is NOT on the website so you need to email and be specific about what caliper you have. These calipers are more commonly knows as "Red Monoblocks. The "Big Reds" are actually 2 piece and slightly smaller piston sizes. The ones T444E Has for sale are pretty much the best 4 piston brake calipers you can buy. Last thing about the brake feel for any forums readers that think these will not work for you. I changed my brake fluid at the time I installed my brakes and used some garbage brand i bought close to my home. (Complications at the time led to that outcome) So naturally my brakes were softer then usual which didn't cause any poor performance on the street, just cause a softer pedal. I have since installed higher performance fluid.
    Now No Worries!
    Mar 2013
    Upstate NY
    M3
    You can totally fit these under 17" wheels as I've done it. Albeit be very few that fit, you can do it. I was running 17x9 Et30 Apex arc-8s with a 12.5mm spacer up front! Gl with sale op.
    Jul 2006
    Hanover MA
    Quote Originally Posted by adam120 View Post
    Now No Worries!
    Thanks for the info! Are the two piece "Big Reds" actually referring to the old 993 style brakes? I've seen those for sale.
    Quote Originally Posted by Mklock View Post
    Interesting. I would imagine it greatly depends on the bracket itself and wheel offset and the use of spacers!
    Thansk
    Jul 2006
    Hanover MA
    Bump
    Thansk
    Jul 2006
    Hanover MA
    Thansk
    Feb 2012
    South Central PA
    1995 530i
    anyone have proof of these fitting under style 19 or style 5s? what rotors? thanks!
    May 2012
    Washington DC
    2004 M3
    I am interested. Are they still available. Please PM me when you get a chance.
    Jul 2006
    Hanover MA
    Bump
    Thansk
    VA
    Several
    Quote Originally Posted by T444E View Post
    Interesting that Rally Road doesn't quote these part numbers as well in their brackets.
    Jul 2006
    Hanover MA
    Interesting that this thread is 7 months old. Clown.
    Thansk
    Toronto, ON/Boston, MA
    2004 BMW M3
    These sell?
    2004 BMW ///M3 Carbon Black/Cinnamon 6 SPD Manuel
    Jul 2011
    Available?
  1. Porsche big red front calipers
    By nine9six in forum Brake Kits, Rotors & Pads
    Last Post: 09-12-2016, 12:58 AM
  2. Porsche Big Red Front Calipers - No Longer Available
    By T444E in forum Brake Kits, Rotors & Pads
    Last Post: 12-25-2015, 08:31 PM
  3. Porsche Big Red Front Calipers - SOLD
    Last Post: 05-04-2014, 11:35 PM
  4. 996 turbo Big red calipers F&R
    By C.Thurman in forum Brake Kits, Rotors & Pads
    Last Post: 10-09-2011, 12:46 PM
  5. Porsche 996 Turbo (Big Reds) Calipers
    By Bluebimma in forum Brake Kits, Rotors & Pads
    Last Post: 07-30-2010, 09:44 PM
