Results 1 to 24 of 24
Thread: Best Choices Headlight Low Beam 9006 Bulb
    RI
    2008 M5, 1995 540i
    Maybe some day I will convert my lights to ellipsoids or something better but for now I am just looking to put in a good bulb thats better than what I have. Will have to check whats in there now, but likely something OEMish bought maybe 6+ years ago by the PO.
    I want something that is compatible with the existing framework with no mods, but I do not want something that is going to burn out in a year.
    I was thinking about getting these.
    HELLA H83300092 HB4 9006 12V 55W High Performance 2.0 Bulb Kit
    https://www.amazon.com/dp/B00O616M6K...v_ov_lig_dp_it
    Other good options?
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2016 M4 Cabrio 6 spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    2013 135i MSport Cabrio DCT
    2012 BMW X5 35d Sport
    2000 BMW Z3 2.8 Roadster MSport Impala Brown
    1992 BMW 535i 5 Spd
    2011 BMW X3 2.8i MSport Alpine White
    1995 BMW 530iA Artic Silver
    1986 BMW 635CSi Bronze Mettalic
    2009 Dodge Ram 2500
    Oct 2003
    Seattle
    99 M3
    SYLVANIA - 9006 SilverStar Ultra
    I’ve been a die hard Sylvania fan, but those Hella’s bring me back to the days of my Lucas Tri-Bar/Hella lights of years past.
    Dec 2004
    CT, USA
    e28, e34, e39
    I went from 9006 to 9012 bulbs with just a small mod and got almost double the light output.
    demet
    RI
    2008 M5, 1995 540i
    Arent the SilverStars prone to shorter life than other high performance bulbs or is it about the same across the board on life of Sylvania, Phillips, Hella, etc.
    Definitely wont stick one of the cheap china brands in there.
    Quote Originally Posted by bluptgm3 View Post
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    1992 BMW 535i 5 Spd
    2009 Dodge Ram 2500
    RI
    2008 M5, 1995 540i
    Details on the mod? Is there a thread on it. Did a little searching and perhaps everyone just gets a kit that has everything you need?
    Quote Originally Posted by demetk View Post
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    1992 BMW 535i 5 Spd
    2009 Dodge Ram 2500
    Dec 2004
    CT, USA
    e28, e34, e39
    Quote Originally Posted by bagekko View Post
    You simply need to file or cut down one tab for the bulb to fit. I think there are youtube vids on the mod.
    Like: https://www.youtube.com/watch?v=iviAlp6x3m0
    And for high beam bulbs you can go from a 9005 to 9011 with the same mod.
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    demet
    RI
    2008 M5, 1995 540i
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    1992 BMW 535i 5 Spd
    2009 Dodge Ram 2500
    USA
    e34 540ia/e32 740il
    Ehh, Sylvania Silverstars are garbage. Any bulb that has a colored coating on it provides less brightness than the clear bulbs. A 9006 bulb is limited by specification to a certain amount of wattage and brightness. All those gimmicky headlight bulbs claiming "Xtra performance" are total bullshit.
    If you stick with the standard incandescent bulb design for the stock headlights (without going to HID or some type of higher wattage halogen bulb) the best option is 9012 "HIR" bulbs made by Philips, Osram, Toshiba or Vosla. They come with an untrimmed upper tab that you cut to size for 9006 fitment. Everything else is the same (including wattage) but the design allowable lumens is ~50% higher than standard 9006 bulbs. Same goes for using 9011 HIR bulbs in place of 9005 high beam bulbs.
    NW suburban Chicago
    hiss by my window
    [QUOTE=m60power;30176842]Ehh, Sylvania Silverstars are garbage. Any bulb that has a colored coating on it provides less brightness than the clear bulbs. A 9006 bulb is limited by specification to a certain amount of wattage and brightness. All those gimmicky headlight bulbs claiming "Xtra performance" are total bullshit.
    QUOTE]
    Agreed. I tried them after hearing rave reviews they also burn out with alarming regularity. There was a class action suit against them I remember cashing a small check after all was done.
    The 9012s sound interesting.
    There is such a thing as TOO bright. Your increased safety ends after you've blinded the oncoming drivers. I could write several paragraphs about some newer cars.
    Mar 2011
    Neverland
    E34 525i
    55W HID or bust. my setup has the same output of a new bmw. my high beams are some fancy LED with light bar output and you can still see the low beams clearly through all of that.
    [QUOTE=ross1;30177021]
    Quote Originally Posted by m60power View Post
    QUOTE]
    theres more to that than simply how bright your car is. for example how high off the ground your lights are, having projectors, properly adjusted beams, etc. Having the best possible lighting isnt easy but imho its 100% worth it. if everything is set up right theres no such thing as too bright
    Feb 2017
    Eldersburg MD
    2011 BMW X5 Xdrive50i
    Is there any way to fit an LED bulb in the OEM place for the 9006 bulbs? I have HID's and I think I may want to remove them as about 25% of the time I turn the headlights on my tach drops out due to the HID ballasts in my car the PO installed.
    thanks
    2011 BMX X5 Xdrive50i - 122K - No muffler, BMS Stage 1
    2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
    1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
    1995 BMW 540i6 - H&R Lowering Springs, Brillstein's, Racing Dynamics Bars, supersprint exhaust, UUC short throw
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by JoeyBimX5din View Post
    thanks
    Pretty sure the 9012s discussed ^ are LED. Might need to address the check control as it may not agree with those bulbs.
    USA
    e34 540ia/e32 740il
    Quote Originally Posted by ross1 View Post
    The 9012 bulbs are a normal halogen (wire filament) bulb that is designed for higher light output. I've never looked into LED bulbs for the 9006 fitment. They probably exist but I wonder if the light would play nice with the stock projector geometry.
    Sep 2002
    USA
    BMWs
    Dude it's 2019, spend $75 on an HID kit or LED setup
    Feb 2017
    Eldersburg MD
    Quote Originally Posted by 5mall5nail5 View Post
    The HID kits backfeed into the cluster / tach on these cars. I don't know if there is a way to get around that or not. Maybe a diode(s)? in the wiring?
    They do make LED bulbs for the 9006's, but I wonder what bulbs may work the best. The prices seem to vary wildly from about 15$'s to around 100$.
    Dec 2018
    Alabams
    E34,e61,e53,z3
    I installed 9012 hIr at the suggestion of this thread and they are awesome. 30 seconds with a dremel and they went in just fine
    Mar 2011
    Neverland
    E34 525i
    yea, relay them straight to battery. Mine used to backfeed really bad and that fixed it for good.
    Sep 2002
    USA
    BMWs
    Weird I've had HIDs on 4 E34s for over 10 years without an issue.
    Feb 2017
    Eldersburg MD
    well this gives me some hope, maybe it is in how the HID's are wired. They are bright and nice, so I do like them.
    Feb 2017
    Eldersburg MD
    Quote Originally Posted by Hofmeister View Post
    so your saying bypass all the OEM BMW stuff, but still run the control through the switch?
    Mar 2011
    Neverland
    E34 525i
    That is correct. As soon as i did this i never had feedback issues again. You will have to mod the LKM to not give bulb out error but youre gonna have to do that with HID anyways.
    Feb 2017
    Eldersburg MD
    The HID's were done by someone else. I don't get a bulb out warning, so it may already be moded.
    Apr 2019
    Zhongshan
    1998 BMW M3 Coupe
    what is most important for led car headlights
    The consumer can most care the differentiated looks/styling and ‘cool’ issue.Next, they care price and reliableness. ( ever had to switch an o.e.m light-emitting diode headlamp?), all good then is best led car headlights.
    The driver will care the performance (quality of light/color temperature and lightweight on the road/down the road, crisp signalling functions)
    More information below website for your reference
    http://www.leishenled.com/
  1. 2003 745i Replacing Headlight Low Beam: HID or Standard bulb?
    By 840ways in forum 2002 - 2008 (E65, E66)
    Last Post: 05-19-2014, 01:53 PM
  2. Headlight low beam bulb upgrade
    By pahhhoul in forum 1996 - 2003 (E39)
    Last Post: 08-27-2012, 12:57 AM
  3. DEPO Headlight Low Beam Bulbs
    By Lailoken in forum 1991 - 1999 (E36)
    Last Post: 08-09-2006, 11:59 AM
  4. 9006 Low Beam Xenon Bulbs
    By sgort2 in forum BMW Parts For Sale
    Last Post: 06-26-2002, 03:00 PM
  5. need help on headlights(low beams)
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 06-04-2001, 07:04 PM
