Results 1 to 7 of 7
Thread: question about differential for a 635csi from 1979
    Jan 2019
    zwolle, the netherlands
    bmw e24 635csi 1979
    he guys,
    im currently working on a 1979 bmw 635csi.
    i want to chance the differential to a limited slip differential ( LSD)
    is there anyone selling a lsd?
    or does somebody know a company that sells a lsd for this model?
    kind regards,
    jelle
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    To begin with I think you should explain "The Zwolle is in Holland. That will save many of us some time as it will limit the amount of people who can help you. A differential weighs approximately 95 pounds so oveseas shipping is probably out of sorts.Which transmission to you have.? There are 2 that can be. There are different differential ratios. Most of the sideloader differentials, that is how they are referred to, that are appropriate for the pre 82 cars, are a 3.07 ratio. These go hand in hand with a dogleg or close ratio gear box. Should you have a standard overdrive 5 speed gear box a 3:45 ratio differential is more in order. These are less common. I think you should post which gear box you have and and where you are located, then those of us that can help you can reply .
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Jul 2018
    Netherlands
    1982 628CSi
    Jelle,
    Maybe I can help, I'll ask around.
    Jan 2019
    bmw e24 635csi 1979
    hello,
    thanks for your replies.
    as bert already said im from zwolle what is a city in the netherlands.
    and yes its a "side loader differential"
    im not looking for a complete differential, just the differential that is inside the case, i already found new bearings and the right crown and pignon wheels.
    so if somebody know if there was fitted original an lsd then i would love to have the oem numbers, or if someone know a second hand or aftermarket lsd thats fine for me too.
    hope to hear from you guys!
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    Side loader LSD's are rare and expensive. Additionally, there are not many ratio options. Most were bought by E9 racers. I swapped out my rear subframe from the e12 chassis to the e28 chassis and this was simple. I then bought an e28 LSD. There are many more ratios and they are far easier to source. Additionally, they run at 50% to 30% the cost of a good sideloader LSD.
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
    Jun 2001
    Bloomington, IN
    E24,E30,E31,E34,E39,E46
    wait. what ? an E28 based rear sub-frame will bolt up to E12 based body mounts ? or is there some modification / fabrication involved...
    Aug 2008
    Sydney Australa
    No modification, no fabrication, just a little fiddly. Then you can pick diff ratio's and buy nice and cheap 3.45 LSD's. It was done as part of my S38B38 engine in build. https://www.bimmerforums.com/forum/s...assis-d-633CSi
    Edit: a few more shots here. https://www.bimmerforums.com/forum/s...d-633CSi/page2
  1. Question about Differential
    By JFV1134 in forum 1983 - 1991 (E30)
    Last Post: 12-17-2004, 01:48 PM
  2. Question about differentials
    By B5Beauty in forum 1983 - 1991 (E30)
    Last Post: 12-26-2003, 06:13 PM
  3. Questions about differential and the fluids
    Last Post: 12-22-2003, 07:23 PM
  4. Question on differentials
    By ines325i in forum 1991 - 1999 (E36)
    Last Post: 02-21-2003, 10:31 PM
  5. Question: 318ti Differential
    By Jared in forum 1991 - 1999 (E36)
    Last Post: 01-01-2003, 12:41 PM
