Results 1 to 6 of 6
Thread: dash gauges went crazy & errors on navi screen
    Jan 2019
    Romania Cluj
    BMW 120D e87
    Hi guys, I am new here.
    Can you please help me with a e87 120d from 2005. I was driving home and suddenly my gauges started moving up and down, like some short circuit was happening. DTC ABS Seat belts, handbrake all errors on the dash. + on the navy screen i got the massage: "electronic failure, you cant continue your journey, DTC failure please drive carefully, ELV failure please stop the car slowly. I discovered that its going crazy just when the headlight are on. As I turn off the lights all the errors diaper. As I turn them back on errors come on to. All mi lights are working fine on the car.
    Any suggestions?
    Thanks a lot!
    Dec 2013
    Chicagoland area
    EXOTICS
    Either your battery is failing to hold a charge, or the alternator is failing, or maybe both.
    But it may be simply loose +/- battery connections or failing engine ground strap connections.
    Dec 2013
    Chicagoland area
    EXOTICS
    Do you own a multimeter/voltmeter? You may be able to perform a simple test of your charging system.
    Jan 2019
    Romania Cluj
    BMW 120D e87
    Quote Originally Posted by MIKYZZ4 View Post
    Unfortunately battery is new, just bought it this summer. The multi meter says 12.5 when the engine is off and 14.8 - 15.00 when engine on.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    “14.8-15VDC” is high. Do you trust your meter?
    Whacky voltages cause whacky issues.
    Jan 2019
    Romania Cluj
    BMW 120D e87
    Quote Originally Posted by MarcoZandrini View Post
    I will try with a diferent voltage meter also.
    The errors apear even if the engine is off, when i turn on the headlights.
  1. help! gauges went crazy.
    By natertater in forum 1991 - 1999 (E36)
    Last Post: 11-06-2012, 06:19 PM
  2. Gas gauge went crazy, then OK.
    By Ken ///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-08-2003, 11:27 AM
  3. My speedometer went crazy!
    By supercharged1.8 in forum 1991 - 1999 (E36)
    Last Post: 07-21-2002, 07:20 PM
  4. GROUP BUY-Chrome dash gauge rings
    By Jimmy545 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 06-13-2002, 10:38 AM
  5. Some dash lights went out. HELP!
    By ryanbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2001, 11:25 AM
