Results 1 to 7 of 7
Thread: Four or two wheel alignment on stock E30
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I'm going to be replacing tie rods soon and taking the car for an alignment. As I understand it, the factory suspension does not have any adjustability in the rear. Do you all with factory setup get all four checked regardless? As a way to look for wear/damage I presume?
    Valencia, CA
    Imola E36 M3 E30 Touring
    You need a front alignment, and a thrust angle alignment, but not a four wheel alignment.
    While the rear is fixed, you have to make sure the front is in line with the rear, which is what a thrust angle alignment does.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    When I did mine, I measured the length of the old ones, adjusted new to same length. All was good. Steered good and tires wore evenly.
    Joliet,IL
    87 325is 96 GMC Suburban
    The places I have been to (with other cars) automatically put devices on all four wheels right off the bat. Your question may date back to older technology in wheel alignment, which some shops may still use. Even when I get new tires on a vehicle they check the alignment with these portable things they clamp on the wheels themselves
    Jul 2013
    CT
    Thanks guys, will proceed with as advised.
    Sep 2014
    KS
    e24e30e36e39e90
    If you're up to the challenge: level surface, two jack stands, some fishing line and a ruler and you can align her yourself!
    Jun 2016
    Pittsburgh PA
    1990 E30 325is
    In the case of my e30, my rear trailing arm bushings and subframe bushings were really worn out and caused issues with the rear alignment. I had one tire wearing quite a bit. I ended up doing the bushings and it straightened everything out. Keep that in mind if they say something in the rear is out of whack!
  1. E30 FS: Stock e30 Wheels Complete Trunk Carpet
    By 1je30 in forum Whole Parts Cars
    Last Post: 01-16-2013, 11:30 AM
  2. FS Stock E30 Wheels
    By mikese36 in forum Wheels and Tires
    Last Post: 04-10-2005, 10:46 PM
  3. WTB: stock E30 wheels with tires
    By Zoeb2s in forum Wheels and Tires
    Last Post: 01-20-2005, 05:00 PM
  4. FS-Stock E30 M3 Wheels with new tires in SoCal
    By Paul-HB in forum Wheels and Tires
    Last Post: 03-08-2004, 10:41 PM
  5. Four wheel alignment
    By Anders in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-11-2003, 05:44 PM
