I'm putting an S54 into my E36, I have the following wiring harnesses:
1.) Z3M S54 Engine Harness
2.) Kassel Performance E36/S54 Adapter
3.) E46 M3 Ignition Harness
4.) E46 M3 Engine / Tran Harness
I have the following questions:
1.) Where does the plug I labeled "C6" in the "S54 Engine/Trans Harness" go?
2.) Where does the plug I labeled "C4" in the "S54 Engine/Trans Harness" go?
3.) Where does the plug I labeled "C5" in the "S54 Engine/Trans Harness" go? I assume it goes to what I labeled "C5" in the "Engine Harness", but would like to confirm!
4.) Where does the plug I labeled "C11" in the "Engine Harness" diagram go?
5.) Where does the plug I labeled "C3" in the "S54 Ignition Harness" diagram go?
6.) Where does the plug I labeled "C7" in the "S54 Engine/Trans Harness" go?, I assume somewhere in transmission?
7.) Where does the plug I labeled "C8" in the "S54 Engine/Trans Harness" go?,I assume somewhere in transmission?
Hopefully others may find my drawings useful. Thanks, Jeff
So I spoke to Jim at Kassel (very informative!, thanks Jim)....
1.) "C6" goes to ebox fan - not used on e36
2.) "C4" in the "Engine/Tran Harness" goes to "C3" in the Ignition Harness
3.) "C5" goes where I thought
4.) "C11" goes to the purge valve
5.) see question 2
6.) C7 goes to reverse
7.) C8 goes to gearbox position sensor (not used in my 5 speed application)
