Results 1 to 3 of 3
Thread: Fire sale!!! 2 car part out
    Apr 2009
    Driverseat
    e38 Msport, 2 e53 x5 4.6
    These were acquired for a project. No longer need both cars
    Parting out both vehicles. Negotiable Pricing.
    Willing to liquidate as rolling shells.
    First Come, First Serve
    PM me with all inquires
    PAYPAL PREFERRED. CASH APP for local sales only.
    Cash is King.
    Shipping available CONUS only
    Car #1:
    Year: 1997
    Model: 540i 6spd Msport
    Color: Oxford Green
    PARTS GONE:
    Front bumper
    Headlamps
    6spd manual transmission
    Manual Pedal Box
    Slave and clutch master cylinders
    shift boot
    Kenwood 6 inch 2 DIN SAT Radio
    AVAILABLE PARTS:
    Air Box
    ABS/DSC brake pump module
    AC Compressor
    AC Condensor
    Alternator (air cooled)
    A Pillar Covers
    Auxiliary Fan
    Front rear axles
    B Pillar Covers
    Brakes (calipers,pads, and rotors)
    Brake Master Cylinder
    Bumper (Rear)
    CD changer (OEM)
    Clock Spring
    Center Console
    Dash board (Tan)
    Differential (2.81 gear ratio)
    Door (front driver side)
    Door (front passenger side)
    Door (rear driver side)
    Door (rear passenger side)
    Door Glass (All four Doors)
    Driveshaft
    DSP Amp
    Exhaust (Muffler and Resonator Delete)
    Cooling Fan
    C Pillar Covers
    Fuel pump
    Fusable Battery link
    Rear Fuse bank (no corrosion)
    Gas tank
    Half shafts
    Headliner (Tan)
    Heater Core
    Heater Valve
    Hood
    Hood Cables
    Hood Latch Assemblies
    Instrument Cluster (Pixels work)
    Ignition set ( 2 keys, DME, GM, EWS, lock cylinder, door lock, glove box lock)
    Interior lighting (front and C pillar)
    M62 non Vanos (has minor oil pan leak. guides done has minor oil leak)
    Manual Sport seats (front, tan)
    Misc Switches
    Parking brake assembly
    Power steering pump
    Power Steering Box
    Radiator
    Radiator Hoses
    Rear Seats (tan)
    Shadowline window trim (sports package)
    Side Mirrors
    Side Marker (Amber)
    Steering wheel with airbag
    Style 42 BBS 2 piece wheels (17x8 squared)
    Struts and shocks (front and rear)
    Springs (lowering springs, Make/ Model unknown)
    Sunroof panel
    Sunroof motor
    Taillights (turn signals tinited)
    Taillight Bulb Tray/Assemblies
    Window Regulators (All four Doors)
    Window switches
    Car#2:
    Year: 2003
    Model: e53 X5 4.6is
    Color: Estoril Blau
    PARTS GONE:
    Wide screen Navigation unit
    DSP amp
    MKIV DVD unit
    Running boards w front and rear fender trims
    M62b46
    Instrument Cluster
    PDC sensors and system.
    Center console
    Interior (seats, door panels Trim)
    Air compressor
    Ignition set (3 keys, DME, GM, EWS, lock cylinder, door lock, glove box lock)
    LCM module
    SZM module
    Air Springs
    Power Steering Cooler
    Transmission Cooler
    Driverside Mirror
    AVAILABLE PARTS:
    Air Box
    A Pillar Cover
    AC Condensor
    AC Compressor
    Axles
    Axle Half Shafts
    Auxiliary Fan
    Auxiliary Water Pump
    B Pillar cover
    Brakes (big brake kit for 4.6is and 4.8is, calipers and rotors)
    C Pillar cover
    CD changer
    Cooling fan
    D pillar cover
    Dash board (all black)
    Differential (front, 3.91 gear ratio)
    Differential (rear, 3.91 gear ratio)
    Drive shaft (Main)
    Drive Shaft (Short/Front)
    Fender (driver side)
    Fender (passenger side)
    Fender flares (rear) front fender trim and rocker Panels
    Front sport struts
    Fuel pump
    Heater core
    Heater valve
    High update European Navigation DVD
    High Update North American Navigation DVD Part 1 East Coast (Digital Copy)
    High Update North American Navigation DVD part 2 West coast, Canada
    Hella Headlamps (2 sets, can be refinished, xenon housings)
    Hella Xenon Ballasts and ignitors (1 set)
    Hood and Tailgate struts
    Headliner (black, sport version)
    Interior lighting
    Manual set and leather book
    Misc Switches
    Passenger side Mirror (power folding, auto dimming)
    Power Steering fluid tank
    Power Steering pump
    Power Steering Rack
    Radiator
    Radiator Hoses
    Roof rack
    Rear 23.5mm Sport Stabilizer bar
    Side mirror (power Fold, Auto Dim)
    Style 87 wheels (front only)
    Speaker and subwoofer set (OEM)
    Transmission (slips will need a rebuild)
    Tailgate trims
    Tailgate (bottom)
    Tailgate (top)
    TCU
    Transfer case
    Washer Bottle
    Wing cover
    Aug 2019
    Kentucky
    1998 BMW 540i/6
    Are any of the m62 non tu parts available? I need a set of cam caps.
    Apr 2009
    Driverseat
    Quote Originally Posted by PanzerShrekd View Post
    Sorry, both cars are gone. All I have left is a tu motor and trans from my e38 which I'm basically giving away minus the heads. But I dont need the bearing caps for I will be keeping the heads as spares only. Which ones you need.
    The bearing caps are the same on tu and non tu m62 motors except for the A1,E1,A5,E5 (because vanos) I've swapped them around before due to stripped oil bar mounts.
    However you will need to replace the ones which have the same assigned location ie: A2 -> A2, E8 -> E8. You cant mix and match them.
    Also depending on how many miles on the donor they can become worn and out of shape. Luckily my tu only had 138 when I pulled it so theres still life in them.
  1. FOR SALE: Full Car Part Out
    By zohanisback in forum 1975 - 1983 (E21)
    Last Post: 10-19-2014, 06:29 PM
  2. SALE Whole car part out
    By GSXRliterbikz in forum 1995 - 2001 (E38)
    Last Post: 02-18-2013, 02:03 PM
  3. Replies: 3
    Last Post: 03-19-2011, 09:26 PM
  4. MEGA GARAGE SALE!!! BMW Cars, Parts(Some NICE/rare stuff) and lots of other things!!!
    By luv4myE36 in forum New York / New Jersey / Connecticut
    Last Post: 11-24-2008, 03:58 PM
  5. Fire sale on Coupe parts! Very cheap!
    By JoshS in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-05-2008, 03:38 PM
