Results 1 to 7 of 7
Thread: M42/M44 DASC question
    Tim @ BMW of Dallas
    98 Z3 2.8
    Just wondering if there are any older folks in here that may know anything about these. I've got a 96 Z3 with a DASC on it. I'm considering buying a 95 318ti and swapping it over (if possible) I've noticed from pics that the throttle body position is slightly different. Any other differences? Would the Z3 version even fit on the M42? Thanks.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Bellingham, WA
    1998 M3, 2001 530i
    Should work well, as far as hardware. The M42 has 100 less cc and makes 5 fewer lb ft. The 318 ECU can be converted to MS41.2 with a flash and anyone can then tune it.
    Sent from my LM-V350 using Tapatalk
    Sep 2017
    Netherlands
    e36 328i turbo
    Quote Originally Posted by mechanicalzen View Post
    MS41.2 on a 1.8 4-cilinder? are you sure about that? I believe MS41 is only for the OBDII straight 6 engines.
    Bellingham, WA
    1998 M3, 2001 530i
    ah, you're right. The M43 ECU is completely different. Looks like TunerPro may be an option, or use the Z3 ECU as is, and hope everything works...
    Tim @ BMW of Dallas
    98 Z3 2.8
    The DME in the Z3 just has a dinan flash on it. Nothing related to the SC. I assume because it's only 5psi? I know the DASC kits came with an adjustable fuel pressure regulator... I assume this is just to bump pressure for enrichment. Seems odd lol
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Bellingham, WA
    1998 M3, 2001 530i
    Quote Originally Posted by Tim95M3 View Post
    A rising rate FPR should be adequate at 5 psi, it won't provide perfect AFRs until full boost, because fuel flow increases with the square root of pressure. The ECU will do its best to compensate.
    Bellingham, WA
    e30
    The 95 is an OBD1 engine and has lots of minor differences. None of them are things that can’t be overcome. I recall the injector bungs being different and some other minor things for hose connections, etc.
    The kits used a RRFPR for fueling increase which was a hack way of adding fuel increase on a stock ECU many years ago. At this point you can find a tuner who can make you an OBD1 chip. It might be easier to find someone who can tune the ECU in Europe as they got a lot more of these engines so there was demand for the knowledge.
  1. E36 M42/M44 DASC Downing Atlanta Super Charger, Dinan Intake, CoP 318i/is/ti Z3 1.9
    By agentj in forum Forced & Chemical Induction Parts
    Last Post: 04-02-2019, 04:25 PM
  2. BMW M42/M44 DASC Downing Atlanta Super Charger - No Longer Available
    By mkmmotorsports in forum Engines, Performance Parts & Software
    Last Post: 11-25-2014, 09:41 AM
  3. m42 / m44 DASC pulley size
    By frankie1000 in forum Forced Induction
    Last Post: 03-09-2010, 10:05 AM
  4. m44 DASC vs m42 DASC ?
    By Danny318 in forum 1991 - 1999 (E36)
    Last Post: 05-19-2008, 11:28 AM
  5. e36 318/z3 m42 m44 dasc supercharger
    By DBarrios in forum 1991 - 1999 (E36)
    Last Post: 06-27-2007, 10:12 PM
