Results 1 to 2 of 2
Thread: Lighting help needed
    spring hill, tennessee
    black 1992 325 i
    My wife has a 2001 325ci. None of the front driver's side lights will work. No headlight, high beam, or turn signal. I've checked the fuses and replaced the bulbs with no luck. Any advice would be greatly appreciated.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It sure sounds like a wiring harness failure. However, the lighting control module (LKM) could be the cause. I’d check the wiring harness in the area of the right front to see if there is any damage. If not, I think the car’s computers will need to be scanned for codes. An obd2 scanner won’t do that. You’ll need to take the car to a reputable indie shop that specializes in bimmers. Try www.bimrs.org.
  1. Head light help needed
    By 9toes in forum Lighting sponsored by BAVToys
    Last Post: 05-16-2008, 12:29 AM
  2. check engine light help needed
    By samfeet in forum 1996 - 2003 (E39)
    Last Post: 04-16-2007, 04:20 PM
  3. Fog Light Help Needed:
    By organic///M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-16-2006, 11:34 PM
  4. LED problem in parking light. Help needed.
    By mihai77 in forum 1988 - 1996 (E34)
    Last Post: 01-18-2005, 10:34 AM
  5. Tail light help needed.
    By AlpineM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2004, 10:35 PM
