Results 1 to 10 of 10
Thread: 06 x3 salvage title
    Jul 2017
    dalton, pa
    1997 740il
    06 x3 salvage title
    I probably screwed up. I bought a 2006 x3 with front bumper cover damaged and was listed as flood damaged by Copart. ($1700 total) 115,000 miles, car starts with a boost on battery and drove it onto trailer to bring home. One question I have, Is it possible that a bad battery would cause issues with 4 wheel drive, power seats, mirrors, rear hatch wont open (locked?) etc. not working or more likely flood damage ruined important computer components? I do see some mud on seat rails but the seats and carpeting look pretty clean. Also the front section sunroof is gone so perhaps took some water before it was covered with plastic. Any input??
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    I would guess that the flood damage is responsible for the other electrical components not working. Did the ECU itself incur any damage?
    888.280.7799 | 6am - 5pm PST
    Jan 2016
    Ca
    2001 525it
    Get a good battery in stalled clear all faults and recheck, flood damage who knows what has been effected.
    Jul 2017
    dalton, pa
    1997 740il
    Quote Originally Posted by jclausen View Post
    After charging the batt my inexpensive code reader showed only coolant code. I have a leak under car somewhere I can check today. I will also check the ECU to see if it got damaged. The car runs and drives but has huge tires (265-17) and perhaps that causes the grinding, clunking noises I am hearing. Thanks for your help.
    Jake
    Wadsworth, Ohio
    BMW
    Many times I've had guys buy cheap cars from places like Copart and they've solved a host of issues by checking fuses/relays/etc. Those type lots are infamous for people harvesting little things off car A to try to check on car B.
    -James
    Jul 2017
    dalton, pa
    1997 740il
    Yes I will do that when it gets a bit warmer. Hoping a bad fuse is the reason the rear hatch won't open. It's hard to understand why BMW doesn't have an inside latch to open rear gate in an emergency. Regards, Jake
    Pittsburgh, PA
    94 325ic, 08 X3 3.0si
    Hey if it keeps giving you problems and can't take it anymore, you would make a good amount of money just by parting the vehicle out. Hell, I'd probably buy a few things as well.
    But, sorry I don't have any advice for you. Hell my X3 was garaged kept and I had to chase around lights and codes.
    Jul 2017
    dalton, pa
    1997 740il
    I'm into this for $1800 total. Do you think I could make that back by parting it? It was a flood car and I don't know the extent of damage caused by water. It runs strong but has huge tires so I havent run it much. Are body parts etc of much value? doors etc.? What would anyone be interested in? Thanks for any input.
    I just want to break even as I just bought a 99 750il I want to keep.
    Pittsburgh, PA
    If there's no mold in the interior and the drivetrain is still good, I'd probably fix it up. Did you make a list of what all needs replaced or repaired? 06 X3 with your mileage are going for 5-7k right now, so I'd probably see the cost of my parts list and if it doesn't exceed 4k, I'd probably fix it. The thing that sucks about parting it out is that it's going to sit on your property till you sell everything and if you don't, you have to haul it to the salvage yard again.
    Up to you though. I wish you luck and if you do end up parting it, I might take a few things.
    Jul 2017
    dalton, pa
    1997 740il
    thanks for the tips. With the salvage title I would guess the going rate to be less (after repairs and rebuilt title) But I do like the car and won't be making any hasty desisions at least until Spring when I can get some work done to it. 0 degrees today! Regards,Jake
  1. '95 E36 w salvage titled worth?
    By Jason C SBB in forum 1992 - 1999 M3 (E36)
    Last Post: 05-04-2003, 09:17 AM
  2. FS:1997 4 Door M3, salvage title
    By Revv Hard in forum BMW Cars For Sale / Wanted
    Last Post: 04-21-2003, 02:11 AM
  3. 1997 M3 Sedan for sale, salvage title.
    Last Post: 04-10-2003, 04:29 PM
  4. So I’m not sure about buying this m3 with a salvage title for 15k
    By track mango in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2003, 03:49 PM
  5. Would you guys buy a salvage title?
    By Ben Carufel in forum Off-Topic
    Last Post: 07-17-2002, 03:48 PM
