Results 1 to 2 of 2
Thread: Problem with retrofit FLA on e60 2006
    Dec 2018
    France
    530xi E60
    Hi
    I added a FLA mirror on my E60.
    So installed correct mirror. Wired to K_CAN_SL and K_CAN_SH.
    Changed the vehicle order to include $5AC in both the LMA and CAS.
    Coded CCC_APP trace and changed VA_LONGDISTANCELIGHT to aktive.
    When I test with INPA in FLA modul, it reads a value that changes when I put my hand on sensor so I think FA and communication is ok
    I can see "high beam assist" in Idrive but when I check to activate, it desaktivates automatically after 1s. What am I missing ? IS something to code in LMA modul ?
    Thx
    Oct 2013
    Swiss
    528iA
    Problems / Fixes
    Problem:
    A. NCS Expert Error when coding FLA: "COAPI-2020 Ecu does not answer"
    B. WINKFP error when coding FLA65: "no answer from ECU"
    C. INPA - UIF: FLA is missing from hardware list
    Reason: Mirror / FLA wiring wrong. Car does not detect FLA
    Fix/Possible causes:
    A. Wire joins/solders/bridges not making contact properly. Check/repair.
    My $10 connectors didn't work so I did the $0 free option.
    Stripped the wires, twisted together & electrical taped. Worked.
    B. Wiring order is wrong. DIY video is misleading. Green/Orange are in wrong position. Swap them.
    If still not working check your other wires. You have made a mistake.
    Problem: Vehicle Order (VO) didn't save. $5AC is missing from list when you check again
    Reason: VO is stored in multiple ECU. Or you didn't FA_WRITE
    Fix: Update your VO in both CAS + FRM + NFRM
    Use EXPERTMODE profile
    Also execute the FA_WRITE job to each of above
    Problem: above is working but: auto high beam doesn't show in cluster
    Reason: These ECUs must be reset: CAS, NFRM, KOMBI, FLA
    Fix:
    NCS EXPERT (EXPERT PROFILE - to reset to factory settings)
    F1+F3=e89 chassis
    F6 back
    F4 - ECU: Pick the first ECU above
    F2 = SG_CODIEREN
    F3 = start coding
    (repeat for the other ECU's: NFRM, KOMBI, FLA)
    Problem: all above working, no high beam assist option in idrive
    Fix:
    NCS Expert code
    CAS: CCC_APPL module
    Change: VA_LONGDISTANCELIGHT
    Now go to idrive - vehicle settings - light - high beam assistant & turn ON.
    Problem: How do I use auto high beam?
    Press high beam 1 time on stalk. You will see symbol in speedo.
    Press one more time to turn highbeam on manually.
  1. Problem with Retrofit HIDs install
    By EBinVA in forum Lighting sponsored by BAVToys
    Last Post: 08-12-2010, 06:51 PM
  2. E60,E61 Sprintbooster for E60 (2006 525xi)
    By AlpineBmwM3 in forum BMW Parts Wanted
    Last Post: 05-31-2010, 05:29 PM
  3. Retrofit Factory Bluetooth to 2006 325
    By bmcdXXx in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-16-2010, 09:38 AM
  4. E60 2006 M5 for sale
    By FAB5 in forum 5 series & 6 series
    Last Post: 09-05-2009, 11:09 AM
  5. OEM E60 2006 M5 Wheels and Tires for Sale
    By blackstar in forum Wheels and Tires
    Last Post: 07-17-2006, 05:28 PM
