Results 1 to 4 of 4
Thread: glove box won't open
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    2001 330ci and the glove box will not open. Any suggestions?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Remove the glovebox by removing the hinge screws. Does the lock work? Try locking/unlocking it a couple of times.
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by MarcoZandrini View Post
    Remove the glovebox...
    The Glove Box needs to be OPEN to remove it.
    OP: Once you manage to open the GB, look at the two Phillips head screws that hold the lock in place - they are notorious for becoming loose. My GB originally did not open unless I used the key. Once I tightened the two very loose screws, it worked fine.
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Yep. unfortunately, i took the lock assembly out, but then read on forum history about the screw problem. reinstalled and works fine. I did notice that when i removed it the screws were loose...as usual you guys were right on....thx.
  1. Glove Box Won't Open
    By 4liter in forum 1995 - 2001 (E38)
    Last Post: 01-10-2017, 12:30 AM
  2. E32 Glove Box: Won't Open
    By LegacyWeapon in forum 1988 - 1994 (E32)
    Last Post: 06-16-2008, 12:09 AM
  3. Glove box won't open?
    By sexybmw330ci in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-17-2008, 08:17 PM
  4. Glove box won't open!
    By Wheels5550 in forum 1983 - 1991 (E30)
    Last Post: 12-30-2007, 12:31 AM
  5. Glove Box Won't Open
    By Onedayjake in forum 1983 - 1991 (E30)
    Last Post: 12-16-2006, 02:01 PM
