$9800 cash
Looking to sell my Biarritz Blue 99 540i/6 in the DENVER area. Been my reliable fun daily for just about 4 years. 131k miles. Car is amazing to drive with the current alignment/wheels/suspension setup. The 3.15 gearing combined with the Helical LSD make for great highway travel. The cruising RPM's are perfect with ample torque available in 6th gear @ anywhere above 70mph. Car runs extremely well and averages 21mpg. The color is rare, pops in the sun nicely and almost looks black at night. Everything in the car works flawlessly.
Volk TE37
M60 manifold
Dinan CAI
Billet catch can
Active Autowerke tune
BC racing coils with Swift springs
Eibach sways
Punched out header cats
Stock primary cats
Custom 3" catback
3.15 Mfactory Helical LSD
Nav with DICE audio integration (3.5mm+ipod/iphone)
Park sensors
M5 seats F/R
Technical graphite interior trim
E60 545i shifter
CDV delete
Rebuilt gauge cluster
*Timing guides inspected @ 115k, no issues.
**Issues: Driver heated seat(butt portion) doesn't work. Rear driver side interior door panel partially disconnected**
***Comes with M5 front bumper***
Maintenance within last 15k:
Water pump/thermostat/radiator&expansion tank/all hoses front&rear/valley pan
O2 sensors/CPS/Cam sensors/Knock sensors
Motor mounts
Gaskets: intake manifold/TB/Timing covers/Valve covers/All exhaust gaskets/CCV gasket
Maintenance within last 5k:
Ignition coils/Spark plugs/Fuel filter/Power steering lines/Both belts & all tensioners, pulleys
ALL front suspension components replaced (lemforder)
Maintenance within last 2k:
M5 clutch/new OEM flywheel/throw out & pilot bearing, pivot fork etc/UUC transmission mounts/rear main seal/input+output shaft, guide bushing etc.
ALL rear suspension components including ball joints replaced (lemforder)
New ABS sensors
Fresh alignment and tires
Fresh gear fluid in trans and diff
California car, no rust
2000 mile oil change intervals
$9800 cash
(right click images>open in new tab, sorry new to forum image posting)
Wow that thing is beautiful!
Sold
